My Emira will likely be garaged at long stints between drives, so may require battery trickle charging.
- Are there particular types of chargers required (so as not to damage the car)?
- How do you connect the charger, then close the boot (I assume you have to do this to set the alarm)?
- If in a closed boot, does the charger generate heat?
