Just clear it, I suspect you'll eventually get other related codes, should be fine
I had both those running and others at the same time it didn't have any effect on my car at all, even on the (very slight) burbling I have on downshifts and decelWhat’s the consensus on the “preferable” code to run around with? Assuming I can’t adjust it out, I can either take out spacers and run P0420 or add one and run P2270 lean.
I guess I’ll trial and error it. There’s a pretty drastic change in sound on mine when I throw a lean code.I had both those running and others at the same time it didn't have any effect on my car at all, even on the (very slight) burbling I have on downshifts and decel
Same.I guess I’ll trial and error it. There’s a pretty drastic change in sound on mine when I throw a lean code.
More info pleaseI’ve had some luck recently with a modified straight spacer. Both permanent P0420 and P2097 codes are gone, and no new pending codes. Happy days.
