Losing my mind trying to find what is rolling around on hard turns
jjslat
Since delivery I have a sound that I cannot locate and haven't seen anyone else with something similar, hoping someone who knows the interior trim better can give me new ideas of where to check.
This sound only occurs on fairly hard left/right turns, never on acceleration or deceleration. The best description is it sounds like a little metal ball rolling through a plastic area. Location wise it sometimes sounds like it's under the shifter linkage area but it really does sound like it goes door to door when I'm turning. It doesn't sound big, sounds like a small ball bearing, it sounds like it's right there in the cabin.
If it sounds like it goes door to door, under the shift linkage maybe something loose on the undertray - like a screw or a pebble?
Could literally be a bolt or nut loose in one of the cross-body channels. Or something in the undertray. Start with the latter to investigate.
Mine did that. It was a small rock in the front tray, under the radiator. Took a lot to get it out.
