JUBU spec Ohlins TTX suspension road & sport (2-way)… PURE ART
For those following along, what @F1 SML8R is referring to is that you can raise or lower your car’s height about 5mm with your OEM Bilsteins.
If you compress your springs and move the lower perch up, there are 3 indentations with a retaining circlip under that lower perch hat. You could move the circlip higher or lower to achieve the 5mm raise or lowering. Looks like it is set at +0 station coming from the factory.
(I used a 5mm spacer for reference of indentation distances)
Some tips for coilover swapping:
(Which is oversimplified in the Service Manual 🤨)
FRONTS:
1. You have to remove the wheel arch liner
2. You have to disconnect swaybar endlink
3. You have to compress spring to be able to disconnect upper coilover bolt from mounting bracket to be able to shimmy bracket and coilover out from upper and lower wishbones
(Ohlins comes with its own mounting bracket where I think other coilovers uses the OEM mounting bracket)
4. Refer to Service Manual for torque specs
5. All bolts were easy to get to using normal tools with minimal extensions needed. Cheater bars make job much simpler.
6. You will play Jenga trying to remove coilover and mounting bracket from wishbones and swear accordingly.
REARS:
1. You DO NOT need to remove wheel arch liner
2. You DO NOT need to disconnect swaybar endlink
3. You DO NOT need to disconnect coilover from mounting bracket
4. Pay attention to offset orientation of aftermarket coilover lower mounting bolt hole for correct side installation
5. See #4&5 tips for Rears listed above
Extra tip:
The wheel arch liners for some reason uses retaining screw type push fasteners which took forever to remove. Take this opportunity to convert them all to push fasteners for future wheel arch liner removals. 😉
Isn’t this only an option on the 2.0i and not the V6?
I believe this is on all variants. Although the spring rates may be different across variants, the design of the OE Bilstien coilover is identical. So all cars have this feature. The real question, is it worth the labor for only a 5mm change?
Someone in a previous post stated that it was 2.0 only.
There's a video of the guys from PB Racing (see the 48 second mark) where he is talking about his new in-house developed springs vs the OE and they show this notch. If you look at the video and zoom in to the exhaust, you'll see it has the V6 exhaust (third cat delete uses a flange mount vs a V clamp wrap-around).
Lotus being Lotus, it could be on some V6's and not others, but given the parts are not theirs, I doubt it. Bilstien probably has this as an off the shelf shock, therefore they should all be identical (sans the spring rates that keep changing).
Looking at the Ohlins TTX potentially for my i4. It looks like they're height adjustable coilovers and on the JUBU site, an option for the 2-ways allows for preservation of the stock ride height. Has anyone who uses the TTX maintained that ride height vs lowering and how is the ride quality? I have a really weird driveway where the stock height is about as low as I can get away with before scraping so looking for a suspension upgrade that doesn't end up destroying my front bumper
Im specifically diverting part of my upcoming Europe trip next month to go and visit Jubu. Just toexperience these prior to deciding, though the Nitrons may also be a possibility as they have the lift kit and the electonic control. These would be the only choices in y mind however Id probably go the three way on the Ohlins as from previous experience you can tune the ride control better.
Unfortunately it will also mean experiencing 600HP in these which Im sure wont be good. :oops:
Ill let you know what I think.
Fyi, i will be selling my set of the jubu ttx 2 ways soon (selling car).
Yes very adjustable heights.
Book spec is 130mm/156mm for front and rear measurement point
I set my TTX's to 111/136mm, and there is approximately 38mm more of damper to slide the collar on, which means you can go to stock ride height, and up to ~20mm higher
Ride quality is very much controlled by the dampers. At full soft, it will make you motion sick as it's less damping than a camry, and at mid-adjustment it's go kart hard. You'll have to play with settings but I'd start at roughly 1/4 up the scale on both compression and rebound and adjust from there.
Reactions: MTV
How much?
Reactions: MTV
Your selling, why would be the first question??
Guessing with the car lowered that scraping is an issue so the Nitrons with the lift system makes more sense. It can’t be that much better than Nitrons. My car scrapes with JUBU front splitter sticking out so I don’t have a choice when I go even lower to maximize the handling.
YEs stock height is always just high enough. Im not really looking at lowering just much better control on track whilst keeping the street manners as well. Maybe 5 -10mm maximum. Ohlins adjustment is good and used them on previous road cars.
PM me if you dont mind shipping to Australia. I may be interested.
