Has anyone completed 1000 miles break in on an AMG car in the US
Curious if anyone has completed the 1000 miles break-in on an AMG car in the US, and pushed the car to max power.
Looking to see if US cars have the same max power in the instrument display as the Chinese cars @ 416hp or 400hp ?
I have a long way to go on my car, had for a month and only have 200 miles on it.....
Reactions: Kaz
I'll probably get it to 1000 miles this month after a few trips to Vegas. AMG Emira in US is 400hp. Does it display in instrument panel?
Yes, both US and Chinese cars are marketed as 400hp, however Chinese owners are have been showing video clips of Emira's with power meter showing 416hp. The cars internal HP meter can be displayed on the infotainment screen and selected to display on the dash.
Just hit 1000+ miles on my i4. Display topped out at 423bp. I gotta say it feels like it. That was in sport mode in auto, on ramp onto the freeway.
  • IMG_4304.mov
    9.6 MB
Nice run ! Think I posted in another thread that the AMG engines would have to be pushing more than 400hp to be under 3.5s to 60mph. Your video helps make that claim, 423hp wow.
Torque maxed out around 499nM or ~368 ft-lbs. Curious what was the approximate outside temp?
We should probably start a new thread with your video, for others to also share their metrics.
It was ~ 45-50deg F. Does anyone know how Lotus calculates bhp and nM that's shown in the display? Wondering if anyone has done a dyno w/V6 and compared.
[Does anyone know how Lotus calculates bhp and nM that's shown in the display?]
It's all calculated from data from various sensors. Mass Airflow, Injector rate, boost, timing, etc. It's not a dyno output figure.
[Wondering if anyone has done a dyno w/V6 and compared.]
Yes, would be nice to have a bench mark from the V6 drivers.
Thanks for temp number, boosted cars are going to make more power with cooler temps.
If it uses vehicle speed or rear wheel speed as an input (I don’t think it does), I’ve noticed my emira overstates speed. Speedometer will show 80mph but Waze reports ~77-78mph. This delta seems fairly consistent at multiple speeds, and is not present in my other cars.
It’s exceptionally common for speedos to read high by a few mph.
In Mercedes cars, the boost and engine speeds are measured, as well as throttle position, intake air mass, and fuel ratio. From these inputs, the HP and Torque numbers are displayed from fixed internal maps or formulas. There is no built in torque measurement sensor on these cars.
I noticed the same.. consistently on a 14 hour trip..
Break-in miles done 4 days in - don't have a picture or video, but results consistent with @JackSlack
Seems really odd for a brand new vehicle with a single wheel/tire combo at launch. Once measured, it should just...work? Even my 2009 911 is more accurate. It's certainly a quirk that I am willing to live with tho. I am really loving this car now that I'm past the break in.
Finally reached 1000 miles. Took a quick run today in Track mode. Infotainment HP indicated 410HP torque maxed out 480 nm or 354 lb-ft.
Will take some more runs next weekend, might show high values in different gears.
Anyone else pass 1,000 miles and want to post there readings.
FYI, think Sport mode caps at 400hp Track mode displays the higher value.
Interesting..... Waze relies on cellular connection and/or satellite link. Is signal latency any factor in measurements?
( if not really, then use Waze as a speed defense during enforcement encounters: For the Drivers in a hurry).
For me, Waze has almost always matched the dash in every other car I've owned (well, except for my '84 308), using the same iphone. Emira just seems to overreport by a few mph.
Waze and Car are about 2mph out, with the car giving the higher speed. At slow speeds i.e. less than 40mph, the difference is just 1mph.
Not sure which is the correct one, but if I had to guess, its likely Waze
I passed break in, but was to focused on driving to look at the HP numbers.
Went through Death Valley and never broke 200F. Temps outside were 106-112.
In my V6 MT, car reads 2 mph too high (at least at highway speeds). Verified with Waze, Apple Maps, and a local speed trap. My old Subaru WR was similar but I think my Tesla is pretty accurate.
Thanks, but how can you leave us hanging on 'the local speed trap' item?
...... Sorry officer, I was trying to calibrate my speedometer and I appreciate your important input. I want you to know I'm a big fan of safety and I'm sure you'll agree that starts with accurate instrumentation. Now that I know what I'm dealing with, I don’t need to take up any more of your valuable time. I think we've accomplished all we need to here, so if you don't mind I'll just be on my way..... with Waze.
