Gold & Silver Emira ULTRAdiscs from Girodisc Have Arrived!
shinoo
🏷 Supporting Vendor 🏷
We received our initial batch of black hatted 2-piece rotors on Friday. Feel free to order: HERE
Gold/Silver are expected in a couple of weeks. They are as beautiful as expected and lightweight.
For those outside the US - I think the scales are showing in lbs so these disks are 20lbs each - so around 9KG.
I'm not sure how much the stock brake disks weigh.
Thanks, My initial thought was how is that saving any weight, before I realised the OP was in the US :)
OEM Lotus disc 9.21kg
Thanks, we need to list the weight in kg as well.
The OEM design is a novel construction that delivers some of the benefits of 2-piece, like weight, with the cost savings of a 1-piece. Ultimately, cross-drilled rotors are not great on track as they crack, but Lotus marketing must feel clients still associated cross drilling with performance. Slotted rotors are the obvious choice for the those looking for more performance.
Gold and Silver hatted (is that a word?) ULTRAdiscs have arrived from Giro. We only have a few Gold left as they are limited. Our standard colors will be Silver.
The gold actually looks way better than the pics that were up before the shipment. They look great. Can you post pictures of the silver? I've been waiting for those. Regardless, purchase coming soon.
Do you have a picture of the gold hatted discs?
Do they rust when wet, like OEM?
The hats are aluminum so won't rust. The iron rotors are zinc plated so should resist rusting for a long time. Of course the rotor face will rust if left for any period of time but that is not important as the pads will grind off the rust immediately on the first drive.
This shade is like our first batch of ULTRAdiscs we did for the Elise 20yrs ago. They look amazing as the wheel area is so dark - these will offer a nice bit of pop.
I will post up images later today/tomorrow.
Brings back great memories from the 4C days…
Yes, we have essentially used this construction on the Elise/Exige/Evora/4C/Atom2/Atom3/Solstice/Sky/Drakan and more...
Please post pix once you mount them!
This weight is for a front rotor? 9.21kg = 20.3lbs, so these Girodiscs save 2 tenths of a pound each (according to the 20.1lb weight shown in the first post)?
I’ll probably install them in a couple weeks. I will weigh OEMs and Giro’s and post pics and findings then. :)
