- Joined
- Aug 6, 2021
- Messages
- 2,712
- Reaction score
- 4,881
- Location
- DC/Virginia, USA
- Emira Status
- Emira Owner
Like many of you, I'm interested in exploring what options exist for raising the rev limit (safely) once my warranty is done.
At minimum, this involves a reflash of the factory engine management or a replacement of the ECM. Both are available, with replacement ECMs from JUBU Performance (Syvecs) on sale now, and MWR (ECUmaster) coming later this year, among others. Reflashes are currently in development from BOE Fabrications as well as a range of other tuning shops. So there will be technical methods to achieve remapping appropriate to this objective.
From what I've read, the limiting physical factor in increasing engine RPM significantly on the 2GR-FE (as supplied by Lotus) is apparently the valvetrain, specifically the valve springs. There are several options on the market to replace these, in varying degrees of increased performance over the stock valvetrain.
Hope this helps to open up the topic for discussion. I'm interested to see what others discover, attempt, and achieve.
Mild: Jubu Performance valve springs for 2GR-FE - 30% harder, good to 7700rpm on otherwise stock valvetrain.
Moderate: MWR valve springs for 2GR-FE - 50% harder, good to 7700+ with high lift. Needs additional retainers and advice from MWR. Claimed good for 8000rpm with titanium valves and other supporting parts. These also seem to be sold by Komo-Tec under their own brand, but those are the same product for 2x the price.
Wild: Supertech kit by Frankenstein Motorworks - Good to claimed 8300rpm with standard lift cam. Includes retainers and caps.
Unknown: Supertech dual valve springs - unknown specs, part number SPRK-EC3025D-2GR. Very high end product, may be very high performance. No longer in Supertech catalog, but exists in fulfillment warehousing. Needs investigation with Supertech to determine complete spec.
