Free Lowering with factory setting VS. GRP lowering kit
I did the free lowering (I paid a shop, so wasn’t actually free) hack today (as detailed by the OP). I can confirm my Sport Suspension I4 (China version), also had the circlips in the highest position, front and rear. After moving the circlips to the lowest position, you do get a noticeable drop in ride height. Unfortunately I didn’t measure it before, but will measure it when I get a chance.
Together with 12mm spacers, the stance is much better than standard IMO. Any reduction in ride height seems to bring the rear wheels inwards, the rear could easily be pushed out another 3mm or so, to better match the fronts, but I’m splitting hairs TBH, it’s looking great as is :cool: :love:
Ride quality about the same?
Can’t notice any difference in ride quality. It was already firm and a little too hard on crap roads, it’s still the same IMO.
Spacers are supposed to slightly soften the ride and I think I noticed that, but it could be in my head.
2 old pics before 12mm spacers + suspension drop and 2 after.
Watch out for extra stone chips with the wider wheel spacer offset, unless you have PPF.
One time, when I was 17, I took my Chevy Camaro to a shop to have it lowered. "Why put on lowering springs," the shady shop owner asked me, "when we could just heat the coils?"
If you're looking for another "free lowering" along with a squeaky, floaty, and unsafe suspension, I highly recommend it.
Great to know that the stock height is adjustable!
Just so everyone is clear, 10mm change on the shock is more that 10mm at the wheel. You would need to measure the lower control arm and do the ratio to get the exact change.
That ride height looks so much better though, like it looks in the configurator.
Is the height adjustment also possible for the tour suspension on a V6?
Heat and compress the coils? Sir, in my neck of the woods we just cut the springs down.
No not possible, or at least not to the same extent. Sport I4 has all shocks set to highest position on the shocks, so there is 10mm movement of the circlip available. I believe that is not the case for the V6.
You sir, learned the wrong lesson from that mistake. :unsure:
Looks great! Is this with 12mm spacers all around or just the fronts? Where did you source your spacers?
Looks great....any vibration at the wheel above 60mph?
First sentence states that he "Can't notice any difference in ride quality".
Ride quality refers to handling, dampening rebound, etc....vibration refers to what driver feels at wheel or seat of pants. Maybe we let the driver who actually made the modifications answer the question (if he chooses)?😀
Spacers don't create vibration. Incorrect installation of the wheel creates vibration.
Porter is definitely not wrong. Surface prep and torque procedure is everything here, it applies to wheels and spacers. Adding spacers adds more prep work during the installation.
Of course proper wheel installation, proper road force balance and torque applications are important but I would assume that's a given. Spacer manufacturing including material used, machine process, hubcentricity, slip-on vs bolt, install prep of said spacer have just as much impact on what you feel at wheel and seat.
Probably 90%+ of us are using 10mm or 12mm spacers made by either PCD Parts or GRP.
They’re all going to be CNCd 6082 T6, hub centric, and slip on.
Two members I think are running 15mm spacers with the same qualities/features in the rear.
A few members are maybe still on smaller 6-8mm spacers which were not hub centric and had some issues installing them due to lack experience with installing those types of spacers which resulted in vibration.
