Door Handle Failure
Hey KitKat, I have the same issue with my driver's side door handle not returning flush with the door after opening. You can push it flat and the door opens fine. Took the car in last week for my second oil change, software updates and for the installation of the water diverter/AC resistor pack shroud that was not installed at the factory. Part for the door handle has been ordered under warranty and will be installed when it arrives. In the meantime. I can live with it...
Yeah I can just live with it for the time being and I'll have to take a deeper look into the service manual on how to replace them.
So I went and ordered both inner door handle mechanisms and replaced my broken one today. If you ever have to DIY this, feel free to DM me for tips. I won’t create a DIY for this because it’s honestly a huge pain in the ass and there are quite a few challenges as the instructions in the service manual are incomplete and don’t cover many of the steps including transferring the body colored handle cover onto the new assembly.
It took me about 2 hours and I could probably speed this up to 1 hour.
The stock coiled spring ended up being unseated from a slotted hole I’m not sure how the new one is revised.
My drivers side has just done the same (RHD). Its due a service but I would rather do what Kitkat did and do it myself.
I didnt have a lot of time so stopped at the point of getting the inner panel unbolted to reach up inside.
I was pretty gobsmacked at the weight of the door card assuming a lot of that will be the speaker.
This was my temporary 20 minute fix 🤡
Hahaha -- this might work for now -- eventually my broken coil spring displaced itself and made it so that the handle couldn't even sit flush before I fixed it.
so this is obviously going to be a problem on the pax side out of warranty as the number of use cycles will take much longer to catch up.......
Oh, 100% that’s why I bought both revised door handle sides, they weren’t even expensive.
On the other hand surely you can find another rubber band? :ROFLMAO:
@kitkat now steady on!
I now need to check if the revised mech price is cheaper than the flowers 🧐
Are they a Lotus part or from a Geely parts bin? I called my local dealer yesterday then gave in and emailed just to book a service so pretty futile going through them i fear
Honestly couldn’t tell from looking at the handles. If you can convince service to do it for free or cheap do that. You got done with the easy part, it’s just a bunch of bolts. The rest of the ordeal involves reaching into really tight spaces to access 3 bolts and separating the door handle cover from the old door latch mechanism without scratching the paint. Not a fun DIY.
...and if we're being honest, you as the owner will be a lot more careful (even if not as killed/familiar with) than any tech. working on it. This is why it's important to always think about what else will be broken/damaged trying to fix topic A before deciding if you should take it in.
what he said ☝️
@kitkat re
Looks like it's P/N 8890572619 which was then discontinued and replaced by P/N 8899012919. Called the following: HDL ASSY-FRT LH DOOR OTR OPENING
Did you keep a record of the new P/N from the RH side? I will have a go at sourcing a pair over here.
Cheers
Had prices back this morning.
In UK both sides are available (upgraded) and will be about £100 inc vat for each side so not completely silly money but enough!
I can believe it. I am told there is more parts availability in the US than here in the UK......... riddle me that???
Funny, and all we hear in the US is, "yeah, we'll have to get back to you on the timing of that part. It's likely coming from the UK."
Soonest I could book it in locally is middle of September.
1 x Second Service
2 x Drivers Door Handle fix (Said they have done a few already)
10 Recalls!!! :oops:
1 x Second Service
You should get a list of those recalls for us, I don't see them listed.
