HiDo you have details for how you connected the Audison DSP?
Is there anything specific you want to know and I can see if I can help?
From what source did you pull the input for the DSP?Hi
That is a pretty easy task if there is a wiring schematic. Is there a wiring schematic for the non-KEF system?Initial impressions of my straight speaker swap is that the mid/high's were pretty good from factory (obviously better now) and the mid-bass is MUCH better. It seems like the Low/Mid/High eq is basically tied to the rear/door/a-pillar, so there's some sort of x-over in the head unit or factory amp.
If the eq was a 10-band instead of the 3-band I could probably make it work, but the low end need some tuning so the only/best option from here is an amp/dsp. I'm tempted to install a 6 channel but I have a hunch I'll still want an 8-inch sub, so 8-10 channel it is. Also, I can max out the volume and it's not super loud, so need some help form an amp.
I assume it's going to be a pain in the ass wiring this thing in, so I'll wait a while. If I get lucky and the factory amp is in the rear PS area (where the amp/dsp/sub will go), then I can basically splice in the dsp/amp (run all wires to the amp/dsp and then tap right back into the speaker wires)...that would be nice.
Keeping things as is for now because I drive with the windows down a lot.
there is no dedicated outputs from the headunit. i also purchased the audsion bcon unit to get best available sound from bluetooth etcFrom what source did you pull the input for the DSP?
I plan to run new speaker out wires from my Audion Bit 8.9. I take it the OEM head unit does not have RCA or optical output, correct?
In the past, I had to pull it from the existing speaker wires to the OEM amp.
Nice find. My first time learning about the bcon. That sounds like a MUCH simpler install.there is no dedicated outputs from the headunit. i also purchased the audsion bcon unit to get best available sound from bluetooth etc
i have been running bcon for a number of years now as the sound quality is much improved ... glad i was of helpNice find. My first time learning about the bcon. That sounds like a MUCH simpler install.
Can you help me understand exactly how you use this?i have been running bcon for a number of years now as the sound quality is much improved ... glad i was of help
tried, 6, 8 and 10 inch sub enclosures that fit neatly behind the driver seat and the only one thats worth the effort is the Hertz Mille Pro MPBX 250 S2 10" Shallow Subwoofer Enclosure. this was the only thing that was able to punch at a decent level, the other subs were very average sounding.Initial impressions of my straight speaker swap is that the mid/high's were pretty good from factory (obviously better now) and the mid-bass is MUCH better. It seems like the Low/Mid/High eq is basically tied to the rear/door/a-pillar, so there's some sort of x-over in the head unit or factory amp.
yes the bcon is attached to my audisson forza dsp amp, it acts as a separate source. you connect via it via your bluetooth on the iphone when you start playing on iphone you will get option to select the bcon as well as using car play. the difference is pretty apparent when you change your streamer to bcon.Can you help me understand exactly how you use this?
I am guessing you have your phone stream to the bcon instead of using the connection through the head unit, correct?
Do you use an iphone with CarPlay?
I am trying to understand the exact configuration and user experience. The bcon sounds like a path to much higher sound quality.
Hacking up the wires for the Audison DSP input is a reason why I did not upgrade the speakers in our other cars. I have done that in the past to three vehicles already, and it is a major chore. This is a game changer for me.
I was planning to go with a 10" JL and build a custom enclosure.tried, 6, 8 and 10 inch sub enclosures that fit neatly behind the driver seat and the only one thats worth the effort is the Hertz Mille Pro MPBX 250 S2 10" Shallow Subwoofer Enclosure. this was the only thing that was able to punch at a decent level, the other subs were very average sounding.
i bought a dap recenlty to check out the LDAC codec that audisson talk about more in their splurge and can state that bass response is better through android. i am mainly an apple user so bcon defintely helps but am impressed with the android.
hope this helps any other questions i will try to answer
hiI was planning to go with a 10" JL and build a custom enclosure.
Did you use the sub that comes in an enclosure or did you build your own?
I plan to build a custom fiberglass enclosure that mounts to the side and extends into the cavity to minimize obtrusion onto the storage shelf.
To make sure I understand properly, you are saying that the sound quality from the Android is noticeably better than the iPhone?
If so, have you tested the sound quality with something like a miniDSP Calibrated Mic to compare the data between the two sources? That would be interesting to see.
I am iPhone user and all of our household devices are grown in The Orchard. I would love to run Graphene on an Android, but have never made the switch.
