Darkworks PBR (parking brake relocator/rotator)
mr.suntorytime
Emira Fondler
Emira of the Month 🏆
⚙️ Supporting Maker ⚙️
My Specs:
Emira V6
Hey eveyone, parking brake blocking your 18" track or safari wheel dreams.
DREAM NO MORE!
Can you measure from the outside of the rotor to inside of stock wheel for us to know what the clearance is if going to 18 inch wheels. Thank you
I think @kitkat mentioned this was the only thing needed for 18s but also having rims that are meant for max caliber clearance would help too
Patrick will have a harder time finding 18" wheels, his rotors are 10mm more in diameter so he has 5mm less clearance to work with than we do.
Unless you're asking because you have CCBs too.
You will need to figure out your clearance over the brakes for 18s, here's a 6 piston stoptech on 18" apex wheels.
Here are the Emira front and rear calipers/rotor clearances needed.
This is a very high quality kit. I've already got one sitting in my garage awaiting some 18" wheels. It's too bad I bought a set of dedicated 20"s for the track. I'd not have done so if this kit was available.
