Custom MagSafe Wireless Charger
1. GRP -
2. ross7alex - pixel 8 pro/9 pro XL
3. virtualmacho - iPhone 17 pro (or whatever the most generic design is)
4. Jon Fuller - iPhone 16 Pro
5.
6.
7.
8.
9.
10.
1. GRP -
5.
6.
7.
8.
9.
10.
1. GRP -
5. Trong74 - iPhone 17 Pro
6.
7.
8.
9.
10.
1. GRP -
6. Lynxz_ - Pixel 8 Pro
7.
8.
9.
10.
@silent cilantro I have an iPhone 16 Pro, but will probably swap it next year. How can this be tackled? Is the tray for the 16 Pro able to accomodate other phones as well? If there's a way to have future-proof compatibility with a newer iPhone or Android device, then count me in please! :) (thanks to @virtualmacho for his suggestions)
1. GRP -
7. Evillem - iPhone Air (it should be similar to iPhone 17 pro)
8.
9.
10.
I've experienced several issues when connecting CarPlay wirelessly. I can only use it plugged. In fact, I disabled wireless connection entirely. That's what's holding me from placing an order atm.
It’s key to fully delete CarPlay profile, then reconnect and when asked, select USB only. This is only way to make sure it isn’t using wireless CarPlay when when plugged in. It’s also the most robust resilient CarPlay experience with best audio.
That said, silent’s tray is awesome and a nice way to stow the phone even if plugged in!
1. GRP -
8. Andrew25 - iPhone 16 Pro and future models (to be confirmed, awaiting Cilantro's response on my previous post #284)
9.
10.
I think a tray that fits an iPhone 17 Pro Max will be pretty universal as it has a horizontal camera bar that extends the width of the phone. Same as the recent Pixels but even taller. An exception would be the Samsung phones with their vertical camera stacks.
Something else to consider is the charging coil is not always vertically centered, depends on the phone. The position of that coil in relation to the camera bump matter because there is limited amount of space in the tray.
I’ll work on printing one for a 17 pro max today to test.
You could do the opposite, just have a raised circle for the magnetic coil assuming all phones follow qi 2.0 standard, that way you don’t have to worry about coil alignment or camera bumps
Yeah I considered having the charging pad proud of the base but that caused some phones with weaker magnets to slide off. That should be easy to make if anybody wants that option though.
Pad/coil location still matters for some large phones so they don’t stick out the bottom of the tray
I have the charger you sold to @GRP and put in his car, which I am guessing is for an iPhone. I am using it for my S25 Ultra, and the magnetic part doesn't hold it steady, but it charges fine. I think my phone is too big and it doesn't make full contact with the magnetic part.
Let us know if that fits an iPhone 16/17 non max nicely and holds it firmly in place! That would mean that one design would fit at least 4 models: 16/17 pro and pro max
