Coolant additives to decrease engine temperatures
For your info..............
I own a 2021 new purchased Evora GT 410 Sport IPS (automatic)
I installed 3 temp. meters and found that these temperatures during moderate driving at 75 mph and 22 degr. C / 72 degr. F. outside temp. are:
1) Engine oil typically approx. 80 degr. C. / 176 degr. F.
2) IPS oil temp. typically approx. 60 degr. C. / 140 degr. F.
3) Compressor cooling water temp. typically approx. 30-35 degr. C. / 86-95 degr. F.
Will let my dealer check all this after my track day. You guys are so helpful! THANK YOU!!!
I put in a bottle of water wetter as soon as I got the car.
On "normal" days, it sits at 85 degrees. On super hot days, the highest I've seen it is 89 degrees.
I did in the engine coolant tank and noticed a difference in engine temps right away.
I also have v6 auto and concerned about cooling.
what are the part numbers for these or where can we buy these in USA
ok for the Thermostat (road/track) this should work correct?
and this is the race only version
you can get this at any autozone just make sure the car is cold and its not at the max line
if you're doing a full flush then maybe use VP Racing fuels Stay-Frosty otherwise the VP Cool Down additive is likely better than water wetter with OEM coolant until you flush for VP Racing fuels Stay-Frosty
And that guy in the video can really talk.
Is there some kind of negative trade off with these additives or why are they not manufacturer recommended and/or already included in the coolants? Can’t imagine it’s just cost when some are so cheap.
