Brake pad install
RyanGphoto
So... I am trying to find anyone that has a step by step guide or install process for replacing the brake pads with the Hawk ones.. (or any brake pads for that matter)..
I am slowing trying to learn to do these things myself, and with the help of a friend I did the short shifter and going to do the shifter plate soon.. but I don't know how involved it is to do the brake pads myself...
If it's complicated, then I won't but if it's pretty easy.. I would give it a go..
Any thoughts from the members here?
Thanks for any and all comments
Ryan G
Brakepads are pretty straight forward to do, but I recommend that you do it together with some one familiar with how ro do it the first time.
This because it quite essential that this is done right as you really don't wanna fuck up your brakes. 😀
If you're gonna track your car I'll also recommend you to change brakefluid to something that can withstand more heat than the standard one.
This because it quite essential that this is done right as you really don't wanna buck up your brakes. 😀
Fair point.. I will NOT be tracking my car at all.. So should I change the brake fluid as well while I am doing this, or does that add quite a bit more of complexity?
Yes, changing brakefluid adds more complexity and if you're not tracking the car/driving very hard on the streets you're probably good to go with oem fluid. (This should be changed every 2. year, as it's boiling point getting lower over time)
