Anyone bleed their own brakes on their Emira?
Blackthought_
Never bled my own brakes before but been watching around YouTube and looks to be pretty easy with the help of a motiv brake bleeder. If I decide to go to a track day I may just try to flush the OEM fluid and replace with motul or SRF. Anyone bleed their own brakes on their Emira? I know the process is the same for many cars but a DIY post would be helpful.
Yeah I’d like to know this too please… going to the garage for some dot 5.1 later this week…
The process is the same as most other cars. Get a pressure bleeder with the specific cap that mounts to our reservoir. To get to the reservoir, you have to remove the bolts holding the front hood down, then remove the plastic shield that covers the reservoir on the left-hand side. I usually pump to 20-25 PSI to ensure fluid will move. Start with the wheel furthest away from the reservoir and work your way to the front.
Lastly, make sure you bleed both bleed screws, not just the outside one on each caliper. I personally like all the wheels off for easy access.
Doesn't mention what volume of fluid is required. FYI i did it recently and used about 650ml
yes. an inner and outer.
And on opposite sides of top of caliper. Inner one fun to deal with, due to poor visibility and tight space. I had trouble with the open end 11mm wrench and worried about rounding the top of the inner nut with the wrench, so opted to crack it open with an 11mm socket (to defeat the initial tightness), then tightened with the socket to reduce the flow of brake fluid, then attached the plastic drain hose, then used the wrench to open it fully for drainage into the catch container. More mess due to fluid loss as soon as the socket loosens the nut, so be ready to sop up with rags, if you choose this method.
flare nut wrench. but I also agree with using a socket initially and to apply final torque with a torque wrench. The angle of force with a socket is a bit better than with a wrench if the bleeders are ever a bit too tight for comfort - you don't wanna snap em off.
