These upper control arms allow the camber to be adjusted from factory to more than you’d ever need. The tyres get wrecked IME on track and there is very limited adjustment possible without going to this sort of upper control arm.
You could just use these on a standard car, you could also add more adjustment with other parts, but these upper control arms could be used on a standard car without changing anything else if you wished. IMO insufficient negative camber is the main suspension issue on the Emira and it means it wrecks the outside edge of tyres on track.
The Nitron Electron suspension kit for the Emira has electrically adjusted shocks, that adjust constantly and can be changed from the cabin.
Personally, I’ve purchased a full suite of suspension parts including the upper control arms above and will be fitting these to my I4 Sport. I will be retaining the factory springs/shocks for now, but will likely go with Nitron suspension in time.
