To cat delete or not delete
mmattt
Emira V6
So I have a valvetronic exhaust on order. Should I still do the cat delete? Local government has put to debate on bumping up noise fines from exhausts ( not approved but probably will) and cat removals are 5k fines. I m probably going to put in the milltek controller as well. Any significant sound difference with the cat delete and titanium exhaust? Major weight savings from the third cat? Or should I just be happy with the titanium exhaust.
I know on a road side inspect they cant see the delete. But maybe the smell. Its also not a civc, so sound will match the looks.
V6 manual fyi
No plan on headers but plan on Inake and jb4. Thanks in advance.
The car with standard exhaust is already pretty loud with the valve open, which I believe will fail whatever noise limit any local ordinances may have already. The decat doesn't make it that much louder - it's not going to be the thing that make or break your exhaust noise compliance. Titanium exhaust will change the timbre and also slightly louder, but here again, it's not going to make or break the noise issue.
As long as you have the valve closed in touring mode, the titanium exhaust plus decat should be quiet enough to pass the noise test.
