Stock pops and bangs
Andrew25
My Specs:
Emira I4
I tried searching the forum for this but couldn’t find an answer. When I first tried the Emira, track mode would give me pops and bangs, which is something that made me fall in love with the car. Now that I reached 1600km, I only slightly tried track mode for 1 minute, and sport mode for 5 minutes. None of them gave me pops and bangs. Is it normal? I have the warning light on the dashboard, don’t known if that might have something to do with it. Thanks!
Hey, no worries.
I did have the P2270 (lean code) come up after I completely messed up a gear change, but that disappeared when the car was restarted, and that was just a one off. So far the spacer has done it job, and I haven't had to mess around with the spacer thickness. I only use one spacer on the 2nd sensor, as the ECU is reading the difference between the 1st and 2nd.
It's worth trying the spacer, as it's only a 2min easy fit.
Thanks for the response, I will try that, spacer on just the second sensor. Will try to pickup a better OBD reader too, I’m told if you use the AMG A45 configuration you can get some special codes that the generic OBD readers don’t see.
If I clear codes after running for a while, it runs fine for the rest of the drive/day, but next day it will be back to LC not working again. I’m guessing it might be out of spec on startup when the cat is cold.
Hey, no worries.
Which exact spacer did you get specifcally, if you could link it, so we can get the same one haha, I know most of them are the same but would be nice to know. Also which downpipe did you go with, im thinking about the grp one.
