Hi,
New to the forum, hoping that someone has some insight to this issue?
I purchased an i4 new (posting here as it may, or may not, happen in the V6 as well?). The car is a first edition (11/24) which I bought on 5/25. At 1000 miles I had both a 'rear right indicator fault' and a flashing malfunction engine light. Brought to the dealer and the only code they could find was code U3003A2 - supply voltage general electrical failures system voltage low. They charged the battery and did a battery load test, both OK. (I have been diligent about charging the battery when parked. Dealer stated that they were unable to duplicate.
At 3000 miles the infotainment screen locked out and a solid malfunction engine light came on. In addition the shifter (in Auto) at 80MPH suddenly shifted from 8th to 4th under constant speed/load and I had to use the paddles to get back into 8th.
The interesting thing is that I don't get the malfunction light on start-up, only after being driven 150-200 miles. If I subsequently charge the battery then the warning light goes away, If I don't charge the light will come on at start-up. I suspect the dealer will put the car on a charger and thus can't duplicate. I don't get any battery charging warning during the drive.
The dealer suggested I contact Lotus customer support, which I did (UK and USA/China). The car has the latest software update but no change.
My (amateur) guess;
I absolutely love the car but don't fully trust it to go on a long multi-day road trip without charging it every night. The car has never failed to start nor had a 'limp mode' while driving. The engine temp never got over 195.
Does anyone have any thoughts?
P.S. I explained all of the above to UK support but they had me e-mail US/China support but not optimistic that they will respond. The dealer has had the car twice for the same issue for a total of 5 weeks but the issue is unresolved, I don't have much faith they know what to do.
Thanks
P.S.S Located in Marin County, California - some amazing backroads here!!
My (amateur) guess;
- battery voltage drops to the point where I get the warning before the car charging system kicks in as I don't get the light when the battery is fully charged at home.
- battery is damaged
- Alternator/voltage regulator is damaged
Thanks
