Squeaky trunk panel
me73
Emira V6
I am generally pretty impressed with the fit and finish quality of my Emira. Quite a step up from my Elise, but it's still a Lotus :).
I noticed that when I would even gently press on the rear finishing panel that attaches to the third brake light when the rear hatch is open it would give a very cheap sounding plastic-on-plastic squeak.
This panel is simply held in place with eight clips. 4 Christmas tree style at the trunk side and 4 metal spring clips (covered by pieces of felt) on the side facing the rear of the car. On my car, they had also used a little double sided foam tape to stick the panel to the adjacent side finishing panels. Once you separate the tape, the panel pops out by pulling up and/or prying up with a trim tool.
The metal clips may stay with the brake light panel instead of the finishing panel. In which case it's easy to remove the brake light with 4 screws to retrieve the clips.
What I found is that there's a fin in the middle of the finishing panel that sits in a slot on the brake light assembly. I assume it's for part alignment. The fin rubs on the slot and makes the noise.
I covered the fin with some felt and placed some 1/16" thick adhesive backed foam around the perimeter of the finishing panel and snapped it back in. No more noise at all. You have to use a thin foam or felt to ensure the panel lies flat against the adjacent panels.
I wish I had taken some pictures but I was just concentrating on getting it done.
Ah thanks for figuring out where to put foam tape. I’ve been meaning to take it apart and do exactly what you did because that plastic squeak is annoying me
