Software Info System and other problems with basically new 2026 Emira
Here's a bigger question(anyone).....how much time can a build date be verse the Monroney(window sticker) year stamp? I'm surprised a 24 can be sold as a 26, to me thats a shocker!! Also, is the build date on the Emira in the driver door jam?
i think two of us answered the same question about different vehicles, i started the thread so this discussion is for a actual 26 model..
Update: The left parking sensor was the thing causing problems and it seems like in some cases there was a factory recall for the plastic triangle mounting panel on the front left. After this being replaced and calibrated that issue was solved.
Next was software updates that seems to have resolved the other iPhone Carplay-related issues and now very occasionally doesnt connect but that is typical of all cars and it no longer leads to cascading system crashes and the other misc crashes stop occurring as well.
AC Problem did not resurface and check engine light was a faulty 02 sensor and that is a common failure that ive had happen on about four other cars and no big deal.
I picked up a 26 V6 manual back on fathers day. It had sit on the dealer lot for 6 months and while doing my around the car inspection it gave me the low battery warning while on accessory mode. When I started the car to leave I got a yellow triangle and a message that some of the various ADAS didn't work. I joked with the salesman that I already got my first triangle and drove home. It was actually a great drive home. No issues with the car and my android auto worked great. When I restarted the car the next time the triangle was gone and all the nannies were in full force. I've driven it twice since then with no issues. I have read on other posts about the volume thing. I haven't really played with the radio much yet but I assume I will have that as well since that seems to be software related.
In my quest to try and de-nanny the car I came across the safety module in the wiring diagrams. Its fuse 14. I was going to pull it to test exactly how many errors I would get but havent gotten around to it yet. It seems to be a dedicated fuse only to that module and does not run the camera or other sensors that I can see.
Just be careful that you are not disabling the SRS module, which has nothing to do with you ADAS and everything to do with your airbags!
