- Joined
- Mar 5, 2022
- Messages
- 2,233
- Reaction score
- 4,204
- Location
- Mountain View, CA
- Emira Status
- Emira on order
I'm not sure about the Emira, but most double wishbone suspensions have similar or less roll center drop for a given amount of cg drop when around ride height. This means as ride height drops you will have about the same or slightly less body roll for a given amount of lateral force. Even if the roll center moves down more than the CG, it would be minimal. One of the big advantages of double wishbone suspension is the good roll center control throughout the typical suspension movement. Lowering cups are a good option for decreasing ride height with no change in ride quality at the increased risk of bottoming out the car or suspension. Works the same way as threaded body coilovers, but just gives you a fixed ride height change.
I'm kind of curious what that piece was that someone mentioned the dealers were taking out to get a slight drop. Do we have any closeup pictures of the Emira suspension where we might figure it out?
I think this depends on control arm lengths and overall geometry. Really hard to know without an actual car to measure and estimate through range of motion.
What the dealer mentioned is likely the circlip position on the Bilstein dampers that the spring seat sits on. I tried looking in past videos where it's configured but couldn't find a good shot.
Edit: The BOE lowering cup site on greg's mentions it in the notes.
Evora Suspension Lowering Cups by BOE
Evora suspension is pretty good right out of the gate. If there's one common complaint, it's the ride height. These lowering cups are designed in-house and will lower the car about 3/4 of an inch. After suboptimal experiences with aftermarket "lowering springs", which were both of inferior...
www.gregsraceparts.com
"NOTE --- If fitting these on a GT please know that it will sit approximately 10-15mm lower than a 400 does with them installed. You may want to adjust the circlip position on the shock body to raise the car slightly for some middle ground on the ride height to avoid rubbing on hard corners and large bumps."
