Poll: I4 Sand Contamination
Do you have sand contamination in your I4 engine?
  • Yes
    Votes: 8 29.6%
  • No
    Votes: 19 70.4%
  • Total voters
    27
Rainier
Please help us gather some statistics on the I4 engine sand contamination issue.
(This may manifest as stuck thermostats, broken coolant pump or other issues with the coolant system)
How many miles until these issues typically develop?
It depends on how much sand residue exists. Here's the scoop, from the few "autopsy" photos that are floating around the "interwebs" it doesn't appear to take much to mess with the water pump and thermostat(s). My guestimate is that if you have this condition, it'll come up quick. Certainly after a few hundred miles of driving.
I think you are right. In my case, they found it hard to tell what stuck the first thermostat. Lotus NA made the call to replace both. Fingers crossed, this was my Lotus glitch. At least I got to wrap codes, updates, 1000 mile service and new car issues all sorted at one time.
Mine showed up at around 1800 miles. Been at the dealership since May 20th awaiting parts.
Thermostats were stateside. Non-reusable bolts weren’t. 3-4 weeks from overseas.
"For want of a nail the shoe was lost;
for want of a shoe the horse was lost;
and for want of a horse the rider was lost,
being overtaken and slain by the enemy,
all for want of care about a horse-shoe nail."
I have no idea if this will succeed, but did you try to get the bolts from a Mercedes dealer?
The dealership is handling it. Not sure if they tried or not. Since this is an issue with Benz and lotus I’m not sure about availability.
i4 with ~1300 miles. No issues as far as I can tell. What signs do I looks for if it comes up?
If you had this, you would have an engine light. As far as normal operating temp, I've been operating at 185 degrees on the low-end, 195-197 on the higher end with an occasional 200 degree pop then quickly goes down to 195-197.
Got CEL around 1300 Km, cleared itself.
CEL on again around 2500 Km. installed OBD checker found P2CEF error code.
Car currently at dealer in Montreal, awaiting update.
I have the P2CEF Thermostat A stuck open code at 108 miles. Headed to dealer tomorrow. Ugh.
Make sure they change both thermostats and properly flush the entire system. If not, it will fault again.
Thanks for the advice! Did you have the same issue? Is it resolved for you?
