Poll: I4 Sand Contamination
Do you have sand contamination in your I4 engine?
  • Yes
    Votes: 9 29.0%
  • No
    Votes: 22 71.0%
  • Total voters
    31
I4 customers should insist on a coolant flush to check for any signs of contamination as part of PPI.
Thanks for the advice! Did you have the same issue? Is it resolved for you?
Mine goes back to the dealer on the 19th the replace the second thermostat. I told them to properly flush or it will come back. They didn’t. If it faults again I might lemon it.
I would not blame you if you did. The thermostat is the key symptom and you want to make it’s 100%.
Got CEL around 1300 Km, cleared itself.
CEL on again around 2500 Km. installed OBD checker found P2CEF error code.
Car currently at dealer in Montreal, awaiting update.
Car back after thermostat change and flush, went down East for 2000km tour with no more problems.
Got mine back on Wednesday after the second thermostat change and flush. 200 miles so far no issues.
Is there a general consensus on how many miles it takes for this issue to appear if your car is impacted? Wondering if after a certain point it would be safe to say you're in the clear? Definitely planning to put some miles on mine, but with it being a third car it won't see a ton of mileage and wanting to make sure I surface this issue before the warranty expires if applicable
Mine came on literally 12 miles past the break-in period. Both thermostats replaced and multiple flushes. 8000 miles since- no issue.
If you understand the problem, it's logical to think that symptoms will appear fairly early in the car's lifecycle. As a recap, the problem is residual sand that is left hardened in the block and was not "power washed" out as part of the block manufacturing/finishing process. Eventually, as a result of coolant recirculation, it gets dislodged and clogs thermostats, water pumps, etc. If the residual amount is high, you will see the problem symptoms right away.
Obviously, there's a chance that even small amounts of residual sand over the years combines with other wear and tear contaminants to clog. However, if you have this problem, it's likely chronic and will show up sooner than later.
I have a possibly related question...is it normal for the temperature to fluctuate as it's warming up? Mine gets to 184 or so, then it seems a thermostat opens and the temperature drops to 174 before stabilizing and climbing back up. This repeats a few times until, presumably, the coolant is up to temp. I've never noticed this cycling behavior during warmup in any car I've owned...is it just normal for the I4 Emira? And FWIW, I have about 4700 miles on mine, first noticed this ~3k miles ago (but I can't say for sure if it was doing this before that and I just didn't notice).
Normal on every i4. It's the thermostat opening and closing based on target operating temp. In the beginning, it's mixing both cold and hot water until they both stabilize.
Just adding another data point, my I4 has around 7k miles and was going into service to replace the steering column assembly (creaking noise in other threads). The day before drop off I got P2CEF - aux thermostat A stuck open, and P0116 Temp sensor 1 circuit range/performance. While driving the dash temp shows 232, and live OBD2 engine temp reading showed oscillation between 144 and 419 about 4 times a second. Obviously something wrong lol with sensors, car ran fine. Cleared codes and drove several times after wth no issue.
Dealer tech at Galpin said it's a common issue and they change out both thermostats and flush the system as normal protocol. Will update after I get the car back and have lots of miles on it.
