Please help with 4cyl wheel info
vito2279
My Specs:
Emira I4
Hey guys, I want to purchase an aftermarket set of wheels for my I4. I only want to go up 1 in from stock all the way around. I would like to know what offsets do I need to get in order for the tires to sit flush with the fenders? I don't want to use spacers. Thank you very much!!
i4 Wheel Specs
Front: 8.5x20 ET 57
Rear: 10.5x20 ET 64
The Braid V6 wheels are:
  • 20x8.5 ET52
  • 20x10.5 ET49
These are 5mm pushed out (more flush) than stock - front and rear. You can probably use that same amount on your i4.
Thank you so much! I had no idea where to find that info. Any info that I need for the bolt pattern? Thanks again
My I4 is running 9*20 ET51 and 11*20 ET57. This pushes the outside of the wheel out by 12mm on the front and 13mm further out on the rear.
Front wheels are same on both I4 and V6, rear I4 are 10.5 wide ET64, rear V6 are ET54
Nice looking setup and sharp color. Thanks for the info!
