folks
any help would be cool
23 1st edition v6 manual ... now covered around 12k miles
was on a road trip in Wales UK a couple of weeks ago and had a faulty o2 sensor (bank 2) and replaced by GRP - their Bosch one
Prior to that the car was running very rich and dumping a lot of fuel in. on removal of the o2 it was black and had soot deposits
This cleared the codes etc i was having. NB 1 sensor replaced, original on bank 1 remains
due to state of o2 sensor i was concerned with potential fouling ofr plugs as car appeared to have a slight misfire. changed all the plugs and replaced a couple of coil packs on those that had a bit of brown staining on the shaft.
With all that done, i done a hard reset on the ECU during the plug and coil service.
I now have a CEL with P0174 via my basic obd2 reader, the codes for o2 sensor, misfire etc have now gone. the car is going into reduced performance mode and i am at the end of my tether with this one.
Have got some advice to check for potnetial intake leak, blocked air filter (which i doubt as purcahsed and installed GRP blue one a couple of months ago) and the charcoal canister connections etc.
Any thoughts?
Modifications wise i have installed the following
Miltek v2 valve controller (its working as it should)
Miltek 3rd cat delete pipe
Miltek exhaust
Any help greatly appreciated in troubleshooting this code
Any thoughts?
Miltek exhaust
