jamesbxxx
I can’t find this anywhere in the display. Surely Lotus wouldn’t miss this off a driver’s car, would they?
The rev limit is lower when it's cold. You can see the red line alter as it gets to 60º and 70ºC water temp.Did they not learn from the Elise camshaft failures due to potentially getting on the motor while the oil was not up to temperate? Hell it should be basic to know your temperature of all your fluids. Good way to indicate problems or to ensure your not to rough on it before it gets to temp.
Thanks for this now I know Have had my Evora GT for 2 years and have been looking for those gauge’s since I got it. Was to scared to ask anyone as I thought they would think I was stupid 🤫Lol, my Evora GT doesn't even have a temp gauge. 🫠
Lotus does not have one. So maybe it should not go on the track. Or maybe it’s not a sports car.There must be an Oil Pressure Sensor - every engine has one!
Plus as a Sports Car, folks like to see the Oil Pressure, especially during Track Days.
Yes it does have one, because the Toyota engine has one. You're likely referring to the gauge, not the sensor.Lotus does not have one. So maybe it should not go on the track. Or maybe it’s not a sports car.
It does have warning lights. But when they pop up on the dash it’s too late. 🙃
The BMW M2 (OG, maybe also comp) has a combined water and oil temp so you don’t even know if one of them is too hot until it’s “too late”, so you can’t go to the track and it’s not a sports car ? Great thinkingLotus does not have one. So maybe it should not go on the track. Or maybe it’s not a sports car.
It did have one (sort of).Its more scary the Evora didnt even have a temp gauge.
This was my thought as well. But according to KJD at the top of the thread, the OBDII data isn't present. I'd like to verify that.Oil Temp and Coolant Temp are standard ODBII PIDs. So, if anyone has an OBDII scanner and an Emira, maybe they could do a quick scan to see if they are getting readings. If you can read the PIDs, then there are lots of ways to get auxiliary gauges displayed, even if it's just a simple phone display app that you can drop in the cup holder.
And don't get me wrong, there should absolutely be a center display screen with additional gauges like that. But there isn't,
Can confirm, looked through all sensors. No oil temp to be foundThis was my thought as well. But according to KJD at the top of the thread, the OBDII data isn't present. I'd like to verify that.
That's disappointing. Did you find coolant temp?Can confirm, looked through all sensors. No oil temp to be found
Further thoughts on this. Lotus embeds a lot of info that can only be accessed through the Lotus dealer scan tool. I wonder if they've chosen proprietary pids for this info.Can confirm, looked through all sensors. No oil temp to be found
❓ QUESTION No oil temperature gauge? Driving pattern on cold start? | Lotus Emira Questions | 9 | ||
C | $420.00 Oil change and HVAC water Diverter info. | Lotus Emira Talk | 3 | |
C | Will relay how much oil change cost. | Lotus Emira Talk | 0 |
