normal engine temperature range for i4
mlmarch
what is the normal engine temperature range-what temp activates fans etc-what temperature changes dash color from blue to red?
Typically I see 185 F on hot and warm days like today. Don't have answers for your other questions.
water temps on mine are 185-200...usually 195 when I look down and this hasn't deviated with pretty hard canyon driving, maybe on track the temps go higher? - modern sports cars tend to run a little warmer this helps with efficiency
also minor note, when I have my engine water temp showing through the OBD2 port it does not ever correlate with the number on the dash, usually lower around 10-15 degrees
