Modal Dampers Available Now!
The adjustments you can make on any adjustable damper will make far more of a difference than any valving apart from the ratio between compression and rebound per adjustment click on one ways. If you can afford it always go for three ways as you can adjust the compression and rebound independently. To do that on one ways you need to re-valve. You can also adjust the rake value to affect under-oversteer, but this is probably best done by camber adjustment. Also, the suspension setup of a car comes down a lot to personal preference. e.g all the spring rates mentioned are too soft for my preference.
Gotcha. Most of my suspension tuning experience comes from the rather unusual tuning for autocross, where custom variable-rate valving with limited adjustment is all we could get away with in my class. When the options open up a bit I am not quite sure what to do. Mid-engine performance tuning for aggressive street use differs somewhat from tuning a Miata to maximize the utilization of slicks on a parking lot in the first two gears. I only have two-way adjustment on my tarmac-rally Evo VIII, and I'll be the first to admit I do not have it adjusted correctly yet. Learning gradually.
A lot depends on use case as well. e.g I've tuned my nitron r1s to give me far more rebound damping than standard. My standard fast roads rebounded uncontrollably down b-roads. I could slow this down by adding more clicks, but then the compression would be too hard/harsh. I re-valved them so now they can be compliant on the bumps and still controlled/planted on rebound. Now the car is so much more confidence inspiring on bumpy/twisty roads. I'm still struggling with sharper turn-in but I think thats a lack of front camber issue which there doesn't seem to be any cost effective solutions for.
He's correct about damping behavior altering ride quality as well as spring rate. I'm more worried about any change in understeer behavior and forward weight shift. Shock valving changes can certainly change perception, but the higher rate will also affect the genuine weight shift. I have a tendency to dig the brakes pretty hard on corner entry to help the front bite. I'm not sure I want the front any stiffer for fear it may resist transfer. I'll wait for more scientific folks to do a little testing before I dive in...My fears may be unfounded, and maybe not.
Call Shinoo at Inokinetic and ask him about the Modals and the technical stuff. Aside from the Modal folks themselves, he'll know the most about them and he knows Lotus cars inside and out. The M1s Shinoo just sent me were specifically designed for Shinoo's shop Emira in conjunction with the Modal engineers so I assume that's as scientific as it will get with the M1s for this application. There was a delay in getting his Emira so he decided to sell them to me.
I guess there's a reason the engineers and Shinoo felt firming up the front and softening the rear made sense. I'm going to trust them on that set up because I don't know anything about that stuff, to be honest.
I was just looking to lower the car to my liking without making it a harsh ride, so the moment you get into understeer and weight shifts, revalves, etc. you lose me. I'm too stupid to understand this stuff. LOL.
So here's my UNBOXING video of the Modals that just arrived today. As promised, @shinoo sent them out yesterday for an overnight delivery. I must say, they look really good. The reality is however, you can't see the dampers unless you lift the car and remove the wheels, so they're hidden anyways.
I would say the Nitrons look a bit nicer if you like that color scheme, which I do, but these are beautiful in person as well.
I mounted the fronts already to the Darkworks Design front mounts, which shave an additional 2lbs on each corner, and make it easier to adjust the coilovers. Torqued them to OEM specs (120nm) as well. Thanks to @mr.suntorytime for the mounts.
I will also do an install video when I get to installing them in the next couple of days.
Weight Comparisons (Please check me on the OEM and Nitron weights)
Fronts:
Modal M1 @ 5.74 lbs each | Nitron R1 @ 5.6 lbs | OEM Sport @ 10.5 lbs
Rears: Modal M1 @ 7.68 lbs each | Nitron R1 @ 6.3 lbs | OEM Sport @ 13 lbs
Total combined weight for the Modals are 26.84 lbs for all coilovers, about 20 lbs lighter than the OEM Sport Suspension. The Darkworks design mounts also shave an additional 2 lbs per corner.
Fronts:
Modal M1 @ 5.74 lbs each | Nitron R1 @ 5.6 lbs | OEM Sport @ 10 lbs
Rears: Modal M1 @ 7.68 lbs each | Nitron R1 @ 6.3 lbs | OEM Sport @ 12 lbs
Total combined weight for the Modals are 26.84 lbs for all coilovers, about 18 lbs lighter than the OEM Sport Suspension. The Darkworks design mounts also shave an additional 2 lbs per corner.
HOT
PSA:
Install the top mounts before installing the new shocks.
This will make installation easier.
Fronts:
Sweet! Looking forward to seeing the install. Are they the same price as the nitron r1s?
These are about $1,200 more expensive than the Nitron R1s.
Have these been tuned and tested for V6? As the Bathurst edition is an i4 (different weight, weight balance, alignment settings etc)
Yes, Modal have fitted many V6s in Australia with great results.
This is the beauty of adjustable dampers. We've been selling dampers (Ohlins, Nitron, Racetech, now Modal) since 2004 for Lotus applications. I agree that Triples are the best, but for the vast majority of customers, the Singles deliver the balance of performance/$. They are the right value prop for most.
Hey papa - waiting for that install vid I subscribed and everything! Please don't do that " I took the tires off and then boom its all done" style. I hope to see all the drama, trip to the ER, and swearing etc. that those of us who actually work on stuff routinely encounter.
The hard part for coil over replacement is removing the old ones and the non captured springs. After that its pretty drama free especially if you have new top mounts.
I'll be as dramatic as I possibly can. Oscar worthy just because you subscribed! LOL
Yep. The biggest b*tch will be the removal of the stocks and the adjustments to ride height afterwards. That's always annoying based on past experiences
Can you maintain the stock ride height with both m1 and m3?
We have not tried but they should come close. I know the suggested settings from Modal result in a 10-12mm drop from stock.
That sucks. Already scrape on my driveway as is with stock height
The ride hieight can be raised by compressing the spring with the perch. It is in your control. I just am not sure how high.
