Manual Transmission Fluid Change
jp129
Emira V6
I've searched the forums but haven't really found anything solid on where the drain and fill holes are on the manual trans. Has anyone done a trans fluid change themselves?
I'm wondering the same. Couldn't find any resources on the forum but I found a video showing the transmission oil change on an Evora. Not sure if it's the same for Emira.
Evora Transmission Fluid Change
I suspect the guide in the factory service manual for the Evora 400/GT will be nearly identical, if not the same, for the Emira.
When I was under the engine bay doing the engine oil change, it wasn't obvious where the drain and fill holes are. What I would suspect is the drain, was plumbed to something. I need to investigate further, but just curious if anyone had direct first hand experience.
Looks the same as the series 2 Evora.
Excellent! Thank you for the link to the thread. That diagram is very helpful!
There is a bit of information in this thread (page 12). I don't think the procedure is identical to the Evora. I can't find more information, but I believe it was confirmed in another thread that the drain or fill plug was in a different location.
Here is a write up..
