Anyone have them they can post? I see they were released on 01/23/2023, however I cannot find a copy (Free).
WTF! Definitely selling within 12 months.If you want to know book time on engine remove and clutch replacement it’s 23 hours. I know because my clutch release bearing needs doing under warranty!!
Kitkat, any chance you might share from your service notes what an "RSC Service Required" is? It appeared on my '24 FE2 dash at exactly the 700 mile mark, and the owners manual reveals nothing about this. Thanks in advance for any advice you might provide!Does posting the service notes pose an issue @TomE ?
This kind of codes are not documented. But I can tell you it’s a Emira gremling that might fixed by an update. If it’s a continuous occurrence it might be water ingress. Don’t sweat it - drive it and it should clear itself after a few miles.Kitkat, any chance you might share from your service notes what an "RSC Service Required" is? It appeared on my '24 FE2 dash at exactly the 700 mile mark, and the owners manual reveals nothing about this. Thanks in advance for any advice you might provide!
Sorry zero mention of that anywhere in the service notes.Kitkat, any chance you might share from your service notes what an "RSC Service Required" is? It appeared on my '24 FE2 dash at exactly the 700 mile mark, and the owners manual reveals nothing about this. Thanks in advance for any advice you might provide!
Geez. Thanks for checking on it for me.Sorry zero mention of that anywhere in the service notes.
Welcome to the family![]()
Thx Kimmax. I've been in "the family" for a while now... had a 2010 Evora from new for 14 years. I'm used to these mysteries, or should I say Lotus charm? Just traded up to the Emira.This kind of codes are not documented. But I can tell you it’s a Emira gremling that might fixed by an update. If it’s a continuous occurrence it might be water ingress. Don’t sweat it - drive it and it should clear itself after a few miles.
A member has also done a tutorial on YouTube that will help with the oil change. Easily found when searched for.Hello guys owner of V6 automatic here. The closest service is 900km where I live, and I need to change the oil after a track day and in general be able to do small maintenance work by myself.
Does anyone have a link or can point where I can purchase the Service Notes manual?
Can you download it in 1 hour? Not used it so no idea but ensure you can otherwise the £50 might be the best bet.Hi guys, another brand new Emira owner, someone from Germany this time
Guess I'll need the service notes as well to realize my planned modifications. So, as the aftersales portal looks different in the meantime - what subscription do I need to download it? Is the one marked in red correct?
