Orchardbike
That’s interesting as mine has only started doing it after `I changed the battery!I replaced my battery and started getting this error. Went in for service in Aug ‘25 and updated CEM module and hasn’t come back.
I started getting that warning following it's first service, and 'updates', it would happen very randomly.
Turned out, one of the modules (I believe it's the one that controls the dash and screens) takes over 3 hours to update via the Lotus portal.
It seems that when mine was in getting updated, they likely ran out of time (I had agreed a specific time to collect my car) and someone decided not to bother doing that bothersome, long update, but had already updates all the other modules in the car.
This mismatch of software/firmware between the various modules was responsible for the random telematics messages appearing.
Once everything was updated and matching throughout the car, everything was fine, never seen it since.
You're using Silverstone now ?Lotus Silverstone (UK) were well aware of the problem and stated that the software update takes an hour to do. So they have clearly seen it before and know which software update supposedly fixes it. Mine’s booked in for a week Friday. Interestingly, my car did it every day for 7 days. It then went to get PPF fitted and was fine when I picked it up. It then spent a day at a different address and again, no warning message. It’s back at home now, so will see if I get a warning message tomorrow. I know i don’t get a good mobile signal where I live, so I presume that this is what’s creating the issue. I therefore also presume that the software update simply tells the car to ignore a low/no mobile signal.
I’m slowly running out of dealers to use !You're using Silverstone now ?![]()
