JUBU and other topics, a combo thread
As I have stated it’s my feeling, it’s that simple. Others have felt that the stock redline cuts off sooner that what’s expected. Maybe the digital screen which yes could be wrong…but maybe not, no one knows.
I had a problem with the car when I test drove it. I didn’t like the hard cut off and it looked like it cut off at 6600 TO ME. So I did something about it. That something was JUBU tune with the 7200 redline. Once again to me it felt like I gained 600 rpms not 400.
I’m sharing my experience yet you want to dissected like it’s not correct. Opinions and how something feels is unique.
For example the Evora 7k redline vs the Emira “6,800” is 200 rpm’s so you can compare these feelings. If we lined them all up drove each back to back I think most would agree that my 7200 feels more than the 600 gained over stock Emira. Again maybe not maybe it’s the dash, but if it was the dash would my new ECU effect that bc I didn’t change any other “sensors” other than ECU.
Everyone will argue their point on here. I really don’t care to make my point. Sharing my experience as others might be feeling the same thing. But yes I’m on the hated brand of JUBU so everything must be argued tooth and nail to make a point lol.
I hate the hard, abrupt cut too.
I've found it does cut at 6800, but if you keep your foot 'in', it drops to, and holds at 6600. I think the harsh cut, and subsequent drop of 200 rpm before it holds at 6600 is what makes it feel so very abrupt. The nice soft 'stammer' , hovering at 7200 with the Syvecs ecu is a breath of fresh air after that stock ecu experience.
Just my humble opinion.
Yea you’re probably right.
I remember my dealership telling me this happened bc their car was new, so I was optimistic, come to find out when I got mine it was just a bad feature Lotus decided felt good.
Yes now it’s perfect and how the car should have came.
I’m not a scientist, but it seems like one way to prove the jubu car changes redline would be to post a photo….
Here you go, 1 photo with stock ecu, one with Syvecs.
So it does indeed show 7000, and not 7200, so apologies to TFS, but there's definitely a change from 6800.
So it does indeed show 7000, and not 7200, but deff a change from 6800.
Yea and as discussed you can take it past that 7k visual redline to 7200. And choose a soft limiter which I have as well.
Actually, I've only just noticed that the spacing changes from the 7k mark (RPM per MM halves).
So if you look carefully, the start of the red ribbon, is actually at about the 7200 mark.
The width of the leading white bit of the ribbon must be pretty close to 200RPM's worth at that more bunched up range.
below 7k, 1000rpm is represented by two divisions, after 7k, that same two divisions represents 2000rpm.
