JClem's Magma V6
digilotus
Australia
mine will be red on red! the magma red exterior is a non negotiable and iv always wanted red leather interior so thats what I have selected. I do keep mulling it over tho, alcantara with red stitching is the other option. hard choice
I've seen this spec in person (magma + red leather) and believe me it works incredibly well. You won't regret it! :)
JClem
JClem
Fetcham, Surrey, UK
  • #42
Day 4 update.
The car is fantastic. The looks, the ride, the noise and I'm even impressed with the build quality of the interior. There two things though not currently working.
The Scorpion tracked isn't working but this is apparently down to Lotus not sending all commands to the unit. The unit itself is running and I can see it in the app but no amount of contacting Lotus CC has helped so far.
Today the air con and ventilation doesn't do anything at all. Switching between auto and manual does nothing and turning the fans all the way up doesn't work either. The vents come on at startup strongly but after a few seconds stop.
Toomanyloti
UK
ring Scorpion - the guy I spoke to sorted mine and even took me through using the app on the phone as the tracker tag. Wasting your time ringing Lotus.
re AC - As with everything electronic when mine threw a wobbler i just took a battery terminal off for 5 mins. Might be worth a try.
JClem
JClem
Fetcham, Surrey, UK
  • #44
I phoned Scorpion and the chap was very helpful but initially said he'd never come across this before. When I switched the ignition on he straight away said Lotus need to send an additional command for it to work. So of course that means dealing with Lotus CC! Three phone calls and online chat conversations later and still nothing.
The climate control has got a mind of its own! I took this video after switching the ignition on.
Toomanyloti
UK
But, in true Lotus fashion the climate control worked perfectly driving to work this morning! 🙄
so this is what i was getting at disconnecting the battery.. the old 'have you tried turning it off and back on again' front line support question 1....
KCMO68_510
Kansas City
The AC is just downshifting for the slow corner coming up.
JClem
JClem
Fetcham, Surrey, UK
  • #48
The attention this car gets!
Whilst washing and buffing this morning my neighbours popped over to have a look around. Immediately after they left two builders from across the road were staring and saying “is that a Lotus?”. Starting her up in track mode went down well with both.
Climate control update:
I took her to B&C who did a software update and the A pillar recall but it needs a new HVAC resistor motor. TBH I can easily live with the AC as it is now.
Still loving it, and have got a road trip to the Peak District this evening. Photos on Snake Pass will be on here soon.
JClem
JClem
Fetcham, Surrey, UK
  • #49
First long trip done! 450 miles in 2 and a half days and I’m happy to report no issues whatsoever. Driving through the Peak District in the sun was fantastic and even the wife told me to go faster!
Looking forward to the next one.
JClem
JClem
Fetcham, Surrey, UK
  • #51
Hydrodipping done. Looks so much better in the rear view mirror.
I’ll probably hit the magic 1k miles tomorrow going to Newlands Corner and everything about the car gets better.
First off the HVAC system is now functioning perfectly. It’s almost as if it also needed running in!
The KEF system gets better and better. I was playing Ed Sheerans collaboration album today and it sounded great. The bedding in mentioned elsewhere seems to work.
The exhaust note has definitely improved over the last 980 miles.
I do have something not working though. One of the lights at the top of the cup holders isn’t working!!
Loving every second of it.
EZcheezy
Texas
where did you go for the carbon fiber? how much was it?
nelly111s
NW England
I've definitely thought about this. I'm using it every day at the moment though so its trying to find the time!
Also having a magma car, I think it would be hard to find the right shade of red for the cover. Bright red may be too reflective in the rear screen and also clash with the magma. A “duller” red - not sure it’s be worth it. If I was an extrovert (I’m not) I’d paint mine yellow to match the callipers.
JClem
JClem
Fetcham, Surrey, UK
  • #59
Maybe just painting the "V6" is enough for me. I hadn't considered the reflection though.
Biggles of Norwich
Norwich
Thanks for posting about Hydro dipping. It looks amazing. Now I want to have mine done!
