JaviLM
Saitama, Japan
After this weekend trip I opened the glove compartment and I found this: the dealer had "installed" the ETC module using double-sided tape, which doesn't really work on the fabric-like surfaces there.
Any suggestions on how to attach it securely? I though about velcro, but I don't think it would work on this surface...
virtualmacho
virtualmacho
Supporting Member
Tokyo, Japan
  • #202
You may want to check to see if there is a bracket stuck to the top of the glovebox. Mine has a bracket screwed to the car, and the ETC unit clips onto it along with double sided adhesive.
forest
Japan
I had mine installed at my dealer.
You should consult with the place where you had it installed.
JonFuller
Surrey, UK
Next I am considering putting a Magcode power port for CTEK next to the rear view camera.
This could be easily done by removing the rear bumper, but we are investigating ways to do it without removing the rear bumper.
We are also considering a digital inner mirror.
But when will we get a parts list for the Emira?
I'm doing the same.
I'm mounting mine in one of the square recesses behind the rear number plate.
I have mounted the number plate on a synthetic piano hinge (at the top) so you lift it to expose the magcode socket and it snaps shut with a couple of magnets, hiding the socket when not in use.
Hinged plate done, yet to fit the Magcode socket.
JaviLM
Saitama, Japan
I checked and there's no bracket. Just the double-sided tape attached to the top of the glove compartment. The ETC unit was provided by the dealer. I just checked the box and there isn't a bracket there.
I'll let them know so when I bring the car in to get the AC unit fixed they will also take care of this.
JaviLM
Saitama, Japan
Mine was done by the dealer too (Lotus Yokohama). They provided the unit and did the installation during pre-delivery.
I'll talk to them about this.
Nick219
Japan
I've been informed by my dealer that my Emira2.0 will be manufactured and shipped to Japan in e/May. Most probably my car will arrive in e/July. After going thru custom clearance/PDI, the car will be delivered to my dealer sometime in Aug. I hope I can take the car in Sep! if any unexpected issue!
virtualmacho
virtualmacho
Supporting Member
Tokyo, Japan
  • #212
Great news! Perhaps some of us can go on a tour before snowfall.
