Yes, I get your point of view and also your preferences. With a 4 cylinder BMW 528i, I already went that route and had a totally custom exhaust system built, and I even went through the entire homologation process in Japan to make it legal to use. But it was very difficult to control, and quite easy to err on the loud side. Besides a 4-cylinder will never ever be able to sound like a 6- or 8-cylinder (I already have proven that point). I do agree with swapping some elements to titanium. Another problem is if you remove or alter emission equipment, you will get into trouble with the law, and May have to revert every time there is an official examination.Totally agreed! That sound from inside is fake and needs to be switched off.. however on the other end I know what this engine can sound from the outside and it is insanely loud (maybe not the best pitch, pops and bangs for some but defo loud) when you decat it with a titanium exhaust.
I prefer all day everyday the turbocharger sound over a whining supercharger sound..
Check this video, the black a45s… same engine only tune the emira baby up to stock 416hp
LoudestA45s
NIMBUSBLACK:sound a little fake? like its piped into the cabin like Audi and others do in their RS lineup (came from an RS4 into a V6 Emira)
The genuinely depends on the implementation.You can't 'switch off' the sound. It's not piped music that they put on the stereo.
Most manufacturers use a tube that originates on the inlet side and ends in a small resonator box on the bulkhead wall of the engine bay.
If you don't want to hear your car, or the noise is intrusive, then simply take the tube out and blank off the end that is on the induction side. 'Problem' solved.
The Alpine A110 does this and there is a blanking plug that allows you to remove the tube.
Amazing that someone finally was able to record what this engine actually sounds like. Every video I’ve heard in the cabin sounds like a synthetic video game coming from the speakers.Is this video representative of the I4 cabin sound or did they put a mic in the engine bay?
The Turbo sound comes across much more than any other video I have watched.
Chapter headings indicate windows down…Is this video representative of the I4 cabin sound or did they put a mic in the engine bay?
sounds like you might hear the blowoff valve after hard acceleration and letting off the throttle.I'm still running in so not able to experience going on/off boost at higher revs. To be honest I've not heard any whistle or dump value sounds so far but I'm hoping for more once I can go above 4,000 rpm. Mine sounds pretty similar to the video - quite bassy but no particular character that you get from a V6, V8 or Boxer engine. Having said that, it's quite loud in the cabin when in sport mode but nice and quiet when cruising in touring. 8th gear definitely helps here.
