Clunking sound from the front of car at idle
trong74
Emira V6
Today, I noticed a clunking sound, which seems to be coming from the front of the car while at a stop light. Has anyone else encountered this before?
If so, what's causing this sound and is it an easy fix?
  • IMG_0006 1.mov
    3.4 MB
Does it change if you turn the steering wheel, i.e. is it power steering related?
After that I would lift the front cover and see if the radiator fan is the source of the sound.
also try turning off the AC to get that option out of the window
Steering? I4 or V6?
The sound is intermittent. It occurred again yesterday, but stopped once i turned off the AC. Any idea of what could be causing this issue?
Steering? I4 or V6?
V6. The noise was heard while idle at a stop and didn't check if moving the steering wheel made a difference. The noise did go away once I turned the AC off.
Try adjusting your fan speed while its clunking. Also try to change where the air is coming out (dash, floor, top etc) see if that makes a diff.
If just the fan though it should be there whether the AC is on or not. a weird issue for sure. You might not be hearing the noise when moving due to other road noises etc.
