Catsailr27
New member
Hi folks,
As the title suggests, trying to identify some mystery substance on the underside of my vehicle.
location: assuming splash shield is removed and you are under the vehicle legs pointing out the back looking up... left side of the vehicle seeming to surround the housing of one the pulley closest to the firewall. Photo of underside of vehicle next to oil pan. Based on my searching that is the AC pulley.
I don't think it's coolant from the water pump, that would be white if dried or yellow/red if actively leaking based on the coolant ive been adding. I know there is a small coolant leak somewhere in the system since I put in about ~1/2 cup of coolant per ~1k miles, but really not sure what to make of that.
My best guess is AC refrigerant dye. ~3 years ago had a shop replace some coolant lines, AC Condenser, and Radiator due to AC not working. Perhaps when they were diagnosing that they added the neon identification dye. But, again, that was 3 years and ~5miles ago. Worth mentioning that I didnt notice it when installing the supercharger 2 years ago but that perhaps was just because i wasn't really working under the vehicle during SC upgrade
So, curious what this substance is and where it's from but moreover curious whether or not I should care or be concerned.
Any thoughts?
Any thoughts?
