Floor mat lugs
AndyVX
Northern Ireland
I removed the floor mats to clean them and for the life of me I can’t get the black plastic lugs to lock back into place to hold them down.
I’ve tried screwing them down and pushing them into place.
Any advice?
JohnHoward
Cheshire, UK
They can be a bit fiddly. They are the same fitting as the Evora. You have to line up the hole in the mat with the fitting, I usually push my finger through the hole to line everything up then press the lug down and I use a 50p piece to tighten it up. If it is not lined up properly, it won't tighten.
It is one of those things that you need to discover 'the knack' !
When I got my Emira and realised it was still the same fitting as the Evora again, I thought " Oh no, not those things again!" There is massive progress with the interior compared to the Evora, but the progress excludes the floor mats!
virtualmacho
Supporting Member
Tokyo, Japan
Looks like I need to import some coins while waiting for the car...
fcajr
Rochester, NY
Try these:
AndyVX
AndyVX
Northern Ireland
  • #6
Thanks for that. Bought them a few months ago and they are working well
LuckysDad
Valley Forge, PA
Try these:
Do these hold/attach better or are they just a different look?
M100man
London
I had a problem with my drivers side . I was out driving and one of the lugs managed to work it’s way loose and rolled in the way of the pedals . The dealer replaced all 4 in the end (passenger side as well ) since they were all badly marked and badly fitting from new .
Aero
Huntsville, AL
Piggy backing on this mat related thread. Has Lotus made any official all weather mats for Emira or have made for Evora in past (so indicate they might for Emira)?
I dont expect to drive mine in bad weather but like to put them in cars if they look good.
