Emira Turbo exhausts
Cheers, that clears that up. I think the pops and bangs need a little enhancement, so looking forward to getting mine fitted.
Hi, what you have been told is not strictly true,
The GRP sports cat has been confirmed to throw a code.
The Arie sports cat is advertised as being developed without throwing a code or CEL
If you dont mind having a CEL, then there are plenty of manufactures on Ali Express that will make a sports cat with a 200 cel cat for sub £500 delivered to the UK.
I purchased the Arie one for £1200 delivered as I didn’t want a CEL which would have alerted Lotus to my modification and possibly void warranty on the power train.
I would not have been that bothered had the lotus ECU code been cracked i would have simply had the CEL coded out as i have done with all my previous Porches McLaren’s and Ferraris.
Cheers
Ask GRP. They come with the titanium exhaust. They maybe able to sell them separately. Our Australian delivered cars don't have a 2nd cat.
Has anyone found a site that sells a 2nd cat delete pipe for the AMG version? All the sites I've visited only sell the v6 bypass pipe.
Thanks, GRP indicated they are working on a bypass pipe for the Turbo. However, perhaps I can order the Australian exhaust section to bypass the 2nd cat....
Cheers
The other guys will throw a code also Im sure, its a very similar design (can only make them so many ways)
Its basic catalyst efficiency code which does not effect the the way the car runs at all, more of an annoyance than anything.
Without tuning a small o2 spacer on the secondary sensor should solve it, we are waiting for confirmation back on that though.
We do plan to make a secondary bypass pipe just working on fixturing etc for them!
Hey. Just confirming that the code does change the sound of the exhaust note. With this code on the pops and bangs disappear.... but other than that I haven't noticed a decrease in the actual cars performance.
I did receive the O2 spacers today, so I will fit and test over the weekend, and come back to you, with hopefully great results. The exhaust sounds crazy when the code isn't present. Beast mode.
I realised I never updated this post.
The O2 spacers work perfectly. No more throwing codes. The exhaust note is just getting better and better the more I use the car. Amazing.
hmm I am not trying to argue and I am no expert on downpipe, but as far as I know some of the downpipes produced in China, such as Mach5 puts a layer of special mineral inside the downpipe to avoid CEL so its not just the design but also material used. My downpipe was installed basically plug and play with zero issue.
I believe @ManuelB also has the Mach5 installed, do you have any CEL?
How long is that mineral designed to last?
which model did you order ?
I have the GRP downpipe and exhaust. I am very pleased with the sound. No idea if its better or worse than others as I've not heard any other systems in 'real life' and you can never get the true sound on the computer.
I was talking about the o2 spacers :)
That depends on your driving style. I have known some that last more than 5 years while others are done in two. This is usually a temporary method for cars that have un-cracked ecu or owners who just dun want to mess with ecu modification.
