Emira GRP Third Cat Delete Pipe and Milltek Active Valve Exhaust Control Install Video
An alternative is using exhaust sealeant. I'm using Permatex 80335 Muffler and Tailpipe Sealer with great results. I don't see any carbon leakage on the joint. Mine was a loose fit, but did not want to expand the pipe in the event I want to change to a GRP Ti exhaust and the tolerances are a certain way.
Good to know that's an option! I expanded my decat pipe and then upgraded to the GRP Ti exhaust without any issues. The only issue with the factory muffler is that the clamp is welded on and is limited in its clamping diameter. The GRP Ti exhaust comes with a really nice clamp that isn't fixed to the pipe and has no issues with sealing the muffler to a wider range of diameters.
Thank you for your feedback. That's great to know.
Correct! The stock clamp is welded and has a spacer between the bolt and the nut, limiting how much it can clamp. The best thing to do is to have a muffler shop expand the decat pipe to 3" and then use a hand expander to gently open up the inlet pipe on the muffler. That allows the newly expanded decat pipe to slide in and then be securely clamped.
I made several 1.5" x 2" shims out of HVAC duct material and slid them between the band of the clamp and the pipe to get around the problem. Gives the clamp bolt enough travel to snug things up nicely.
Has anyone done installation in a shop in Socal? I am in LA, and I am definitely not handy enough to pull this.
This job is easily done by any muffler shop. They may want to cut out the OEM pipe to speed things up. I'd suggest telling them not to and that you want to keep the pipe, so you can sell the car with all its original parts.
I tried installing the 3rd cat delete tonight but failed. The OEM Y pipe flange where the 3rd cat delete flange would not sit flush properly. Upon further inspection, the inside of the 3rd cat delete (flange side isn't perfectly round so it wasn't sitting flush no matter how much I tried shimmy it into place. I do not have a die grinder or a dremel to fix the problem. I messaged Greg to see if he can send another one out. Also, the pipe was noticeable smaller and fit really loose on the exhaust side. IMO, there should be more QA done before shipping these 3rd cat delete. This install caused me a lot of frustration and wasted time.
Below is a picture of the measurement I did before using the exhaust pipe expander.
