Custom wheel pictures
Rear
10.5JX20 ET42
Front
8.5JX20 ET47
Stock tires PS2
Thanks for the info.....assuming you have a V6 since you went with ET 42 in the rear?
Are you happy with this setup? Would you do it the same or change anything?
I am happy with the setup. Before, I had 12mm spacers front and back on the stock wheels. I felt like it needed a bit more concavity on the rear tires. That being said, with this new wheel design the car looks much more aggressive and overall compliments the side skirts and front spoiler. Here’s another image of the wheels before mounting.
I have an i4 with 360 hp. Can anyone tell me if the offset (ET) is the same for the V6 as it is for the i4?
Thanks.
I4 offset (edit to avoid confusion: this is for the rear; front is the same for both) is +44mm vs +54mm for V6., IIRC.
El desplazamiento I4 es +44mm vs +54mm para V6., IIRC.
Llevo separador de 12 mm y el neumático Goodyear sobresale de la carrocería unos 3 mm aproximadamente con ET+44. Con ET+54 el neumático saldría mucho más, ¿verdad?
I4 offset is +44mm vs +54mm for V6., IIRC.
I have a 12 mm spacer, and the Goodyear tire sticks out about 3 mm from the body with an ET +44. With an ET +54, the tire would stick out much more, right?
The other way around, unless I'm very confused. Larger positive offset (with everything else the same) means tire is more tucked in.
Very healthy weight savings for forged vs forged. On top of higher load ratings. Win win win
Does anyone know for sure the ETs for the V6 and I4?
Thank you very much.
