Can you Change the Assistant Voice to Female?
RoryBellows
Mmmm Grapey
Emira V6
I can change the language but I would like to change my assistant voice to female if possible. Is there an option somewhere?
Hi All, I am new to this forum having just purchased an Emira V6 manual. I have attempted to make several phone calls using the speech button on the steering wheel (iPhone connected via Bluetooth), using a short press. However it will not recognise any of my phone book contacts ie Jo Blogs etc via my voice !. Doesn’t sound normal function and I’m wondering if I am doing something wrong ? Following the same process in my Ford Focus ST and all works very smoothly in the Ford.
Thanks
Long Press to activate voice on iPhone.
Thank you, just to be clear a long press on the steering wheel speech button will then enable operator to say “ call David Smith mobile” ?
What does a short press on speech button enable user to do ?
Car is with detailer for PPF, so unable to test.
Short press = Lotus Emira voice assistant (Emira navigation, Media, mute/unmute media volume, phone, climate control)
Long press = iPhone/Siri (if phone is connected to carplay - anything you can ask Siri to do on an iPhone)
If memory serves there is a Voice Command Examples option in System Settings - but I only looked at it once, do not remember what was in there..
Hi Wiz33, having now got my car back from the detailer, I was able to test making a phone call using the steering wheel speech button.
If I connect my iPhone via Apple CarPlay then yes I can successfully make a call using steering wheel speech button
If I connect just via BT, I am unable to make a call via the steering wheel speech button. The system appears to not download my contacts.
This seems incorrect to me and wondering if anyone else sees this same issue ?
