Price: USD373.69 including logistics
Engineered exclusively for the LOTUS Emira, these track-grade upgrade paddle shifters eliminate the limitations of traditional fixed-travel paddles, solving the common pain points of poor adaptability and monotonous operating feel. Featuring a hardcore combination of lightweight carbon fiber paddles and high-strength aluminum alloy bases, they deliver the perfect balance of competitive feel, structural durability, and precise shifting response — bringing professional-grade shifting performance to track driving and aggressive maneuvering. By swapping different base plates, they can be adapted to fit various vehicle models.
I. Core Highlights
3-Speed Adjustable Travel Design, Adapting to Different Driver Preferences
Combined with Crisp Metallic Shifting Sound for High Shifting Recognition
Unlike conventional fixed-travel paddle shifters on the market, these LOTUS paddle shifters feature an exclusive three-stage travel adjustment mechanism that allows drivers to freely switch the shifting travel distance based on finger length, driving scenarios, and operating habits:
1. Adjustable Travel Based on Height and Finger Length
3. Signature Crisp Metallic Shift Feedback Sound | Tactile + Auditory Dual Confirmation for Confident Control
These adjustable travel paddle shifters feature a mechanical trigger design that emits a sharp, crisp metallic click sound when engaged. The sound is highly distinctive, completely eliminating the soft, silent, and vague shift trigger issues common with ordinary paddles.
4. Right-Angle Edge Design on Paddles
Designed with motorsport scenarios in mind, drivers wearing thick fire-resistant gloves still enjoy clear fingertip feel, able to distinctly sense the paddle's position and angle. The right-angle design also effectively prevents angular displacement or sliding between the paddle and glove, enabling more precise driver operation.
II. Material & Craftsmanship: Dual-Material Hardcore Combination — Lightweight Meets Structural Strength
1. Competition-Grade Carbon Fiber Paddle Face
The paddle body is forged from carbon fiber material with a classic carbon fiber texture on the surface. Not only does it deliver a sporty visual aesthetic, but it also achieves lightweight design, significantly reducing paddle pressing inertia for a crisp, non-lagging shifting feel. The surface is wear-resistant and scratch-resistant — even with intense, frequent shifting, scratches and wear are unlikely, maintaining a refined competitive appearance for long-term use. The paddle surface is clearly engraved with "+" for upshift and "−" for downshift markings, allowing quick and precise identification of shifting operations during driving and preventing accidental touches.
2. High-Strength Aluminum Alloy Mounting Base
The mounting base connecting to the steering wheel is crafted from aluminum alloy. Compared to ordinary plastic bases, its deformation resistance and fatigue resistance are maximized. During high-frequency shifting on aggressive track days, there will be no base loosening, deformation, or rattling issues. Precision-molded to fit the LOTUS factory steering wheel mounting positions with high fitment accuracy, installation is solid and free of play — ensuring stable shift signal transmission from the hardware root. The base incorporates a dedicated control circuit board that instantly transmits upshift and downshift electrical signals to the vehicle's ECU the moment the paddle is pressed. Shifting response is sensitive and lag-free, eliminating the power connection gap caused by shift delay.
III. Stable Electronic Control System, Lossless Signal Transmission
The base features a custom wiring control motherboard, paired with standard red/black power signal wiring harnesses. The wiring method is clean and standardized, connecting losslessly to the original vehicle's steering wheel wiring without damaging the original wiring structure. After installation, it is fully compatible with the factory shift program — signal transmission is stable with no packet loss, no delay, and no garbled signals. Every paddle press accurately transmits the upshift/downshift command, delivering stable and reliable control feedback whether it's continuous track shifting or daily manual-mode commuting shifts.
IV. Product Compatibility & Usage Advantages
Applicable Scenarios
Track competitive driving, aggressive mountain road maneuvering, and daily commuting interior performance upgrades — a must-have competitive steering wheel modification for LOTUS owners who value aesthetics, control, and practicality.
Packaging Specs
Net Weight: 156g
Gross Weight: 336g
Package Dimension: 223mm × 179mm × 55mm (L×W×H)
Business Information
This product is available for finished goods sales, and we also accept custom development for distributors and automakers.
With complete domestic and international certifications, we support export sales. The product holds three domestic patents plus global patent protection.
- 1.60m – 1.70m height: Gear 3 – Short Travel
- 1.70m – 1.85m height: Gear 2 – Medium Travel
- Above 1.85m height: Gear 1 – Long Travel
- Short Travel Gear: Ideal for track enthusiasts pursuing ultra-fast shifts. With a shorter paddle travel distance, fingertip pressure is all it takes to complete upshifts and downshifts, dramatically improving continuous shifting efficiency. The shifting rhythm flows more smoothly during aggressive cornering and straight-line acceleration in competitive and track driving scenarios.
- Medium Travel Gear: Balances daily commuting with occasional spirited driving. The shifting feel is moderate — neither so short that accidental shifts occur, nor so long that response speed is compromised.
- Long Travel Gear: Suitable for drivers with longer fingers. The damping travel is ample, with clear fingertip force feedback and maximum shifting operation recognition. It effectively prevents accidental paddle contact during high-speed driving, offering a higher margin of control error.
- During daily commuting: Even with the engine's natural exhaust note and ambient cabin noise, every upshift and downshift click is clearly audible. No need to look down or consciously feel for confirmation — you'll know the shift command has been successfully sent by sound alone.
- In track competition scenarios: Drivers wearing helmets, balaclavas, and racing suits are insulated from most external noise and body feedback. Body vibration and physical feedback are significantly reduced. This paddle shifter's signature crisp metallic sound, paired with its firm and precise tactile press feel, creates dual auditory + tactile feedback.
- Precisely fits the LOTUS factory steering wheel mounting structure — original-position lossless replacement upgrade, no destructive modifications such as drilling or grinding required; easy installation.
- Carbon fiber sport appearance — elevates the interior's competitive atmosphere, delivering maximum track cockpit visual impact through lightweight modification.
- Aluminum alloy base eliminates loosening and rattling — high structural stability during prolonged aggressive driving, with durability far exceeding other plastic paddles.
- Three-speed adjustable travel — personalized adaptation to different driver operating habits, balancing beginner-friendliness with professional driver competitive needs, breaking through the usage limitations of traditional fixed-travel paddles.
- Adjustable travel shifting feel combined with crisp shifting sound — allows drivers to clearly sense every shift feedback whether in daily driving or fully-geared track driving, enhancing driving operation comfort while improving shifting efficiency.
Net Weight: 156g
Gross Weight: 336g
