Windshield Wipers stuttering
So am I, since a 22mm size should be too wide to slide in the wiper arm's fitting. I measured (shown below) the OEM blade as well as my replacement blades top lock adapters (which are identical in design and fit perfectly) and both measure 19mm in width.
Having observed more closely, I noticed that your blade's top lock (22mm?) adapter is not a perfect fit as there's a visible gap in the circled area, which is not the case with my 19mm (2nd picture). I'm led to believe that your adapter has a slightly different design.
