Unofficial GRP Lowering Kit Installation Guide
Savanna7
My Specs:
Emira V6
Hello All!
I recently completed installing a number of parts on my (new to me) Emira. I typically film everything to help out others, but this time I got a bit lazy and just created an installation guide. I want to be clear, this is in no way endorsed by GRP, but I felt like more info on this matter would be helpful having just done it myself. Please find the attached pdf with installation steps and photos below. Hopefully it helps the next installer!
(Also, being my first post, throwing a few photos of the car in here prior to installation. I'll try to get some post-installation photos this week.)
I love the livery, and thank you for sharing the lowering kit installation! Welcome to the forum!
Welcome! What a great introduction - you come bearing gifts!
Great livery. And I like that you continued it into the door jam. People rarely do that level of quality.
Thoughts on the lowering? How’s handling? How’s ride comfort?
I love the Emira but feels it rides way too high. Doesn’t give me as much confidence as I want
@sixspeedstephen So far, I have only driven it around town maybe 10-15 miles. It's very compliant and feels as though it rides as normal. I'm sure with a slightly lower center of gravity, it has some effect on handling, but the real advantage will be once its corner balanced.
I don't intend on tracking this car, as I have a separate dedicated track car. Because of that, I think this is a fantastic streetable compromise to aftermarket coilovers.
Awesome job on that! Thank you for the effort in making it!
We will link to it as a resource on our site.
No worries at all. Hope it helps! If a video would make it easier, next time I have her apart I’m more than happy to talk through it.
I really like the rear set up, but the front looks a bit low. Is there a way for the kit to have the same gap in front as it has in the rear? The gap above the wheel between the top of the tire and the fender
Absolutely, but from a performance perspective, that’s not at all what you want in a mid engine car. If you’re not tracking it at all, it won’t matter. I tried to keep it consistent with the 9mm factory difference front to rear as read on this forum.
The challenge was, I have to take the forum specs to be true as I forgot to measure prior to taking her apart.
It's a shame you didn't film the process. I am planning on installing these sleeves soon and would love to have a video as a guide.
I watched obsessed garages install of the nitrons so at least some of the initial removal steps are included there.
It's pretty straight forward. Most of the questions I had were oddities around how they sat differently on the shock from back to front, how tight the lock nut had to be, and initially how the heck to get the front shock top mount in and out. Stick to the guide, use an impact driver, leverage a jack for hub articulation and you wont have any problems.
Not the best lighting, but here is the "after" of the lowering perches. So far, I have only scraped once on a bit of a "launch" in an intersection. She clears all average bumps at this point.View attachment 69749View attachment 69750
Your front looks lower than possible without the nut making contact with the lower control arm during adjustment. Were you able to adjust it down that low by hand after install?
I originally installed my fronts a bit too low and I wasn't able to turn the nut on the collar because it was making contact with the control arm. I had to remove them, adjust them back up higher, and then re-install them. Before all that, mine looked almost exactly the height that yours sits now so I'm just curious.
Also, keep an eye on your rears with the CV boots. If you go too low the collar and/or nut will start to dig into them. Yours looks like it might be OK but it's borderline from my experience.
I set them before install. I did raise it slightly while on the car, but I had to jack up the suspension just enough to clear the nut without preloading the spring too much. My back is definitely clear of the boot at this time. I may end up lifting the front another 1/8 - 1/4 inch or so but we'll see. So far I havent had any problems.
How are you feeling about your set up after a few more weeks of driving it? Any issues rubbing against the CV boot?
car looks great did the livery come from a file or custom made.
I think it's perfect at this point. No rubbing of any kind. The rear as listed above is still in the same place with no issues on the CV Boot. (I read somewhere that different cars may have different boots. If that's true I would be hesitant to state it should work for ALL cars, but my boots were rather large.)
I did end up raising the front 1/8 which made for somewhere around a 5.5mm difference. Not as close to the 9mm stock difference, but the car is still pretty sharp. Hoping to hit a track day this month to see how she feels.
It's custom. I pulled a few images from the GT4s listed online and asked them to replicate it to the best of their ability. We discussed line/gap widths and where they start and end a bit, but otherwise they just got it done.
Reactions: GRP
