- Joined
- May 15, 2023
- Messages
- 189
- Reaction score
- 418
- Location
- Fetcham, Surrey, UK
- Emira Status
- Emira Owner
Does anyone know of third party badges that will fit the Emira key? As you can see mine seems to have suffered over the last 5 months.
5 months with your Emira... keep rubbing it in... (pun intended) 😁Does anyone know of third party badges that will fit the Emira key? As you can see mine seems to have suffered over the last 5 months.
Some folks are indeed a bit touchy about that.5 months with your Emira... keep rubbing it in... (pun intended) 😁
That should be a warranty replacement.Does anyone know of third party badges that will fit the Emira key? As you can see mine seems to have suffered over the last 5 months.
I had the same issue and found a 3D domed Lotus mini badge (18mm) from Divine Handicraft - only £3. Fits perfectly if a little raised but did the job! See picDoes anyone know of third party badges that will fit the Emira key? As you can see mine seems to have suffered over the last 5 months.
Glad someone found you a solution, that looks pretty beat up! I liked the shiny black and chrome finish as well as the badge but figured if it went in the key basket with others it would pick up a ton of small dings and scratches. Thought the same would happen in my pockets too if there was change or other keys in there, so I keep it "quarantined" on its own when in a pocket. Any key would suffer the same and the only reason my previous Vantage key didn't is it had its own leather wallet - but these were not the answer as they were absolutely notorious for the key slipping straight out and getting damaged when it hit the tarmac, often quite badly...Does anyone know of third party badges that will fit the Emira key? As you can see mine seems to have suffered over the last 5 months.
We can defintely make badges for these, just need an exact measurement and we can get them done!@GRP sells some replacement key badges for previous models, but they're 12mm (I think you need 18mm). Might still be worth reaching out to them since they might offer Emira sized replacements soon.
Couldn't find one without black pack? 😄
I've had both of mine in Faraday bags since last January, one in the safe which I alternate every so often. They're still as new.......I will be keeping mine in a Faraday bag to keep the car from turning itself on constantly, so I'll be sure to use one with a soft lining.
I definitely need one if you make them. 12 months and 11k miles means my badge is not looking goodWe can defintely make badges for these, just need an exact measurement and we can get them done!
We should have our car soon and we will measure to get these made.I definitely need one if you make them. 12 months and 11k miles means my badge is not looking good
I don’t think these fobs are very good at all and I’m pretty sure they are not metal on the sides because one of mine has tiny chips from the previous owner dropping it I guess. I think it’s bad that a lot of solutions involve covers when it should have been up to the standard of the rest of the car.Does anyone know of third party badges that will fit the Emira key? As you can see mine seems to have suffered over the last 5 months.
Or...a 100k car and a $10 fob that would cost $300 to replace.I don’t think these fobs are very good at all and I’m pretty sure they are not metal on the sides because one of mine has tiny chips from the previous owner dropping it I guess. I think it’s bad that a lot of solutions involve covers when it should have been up to the standard of the rest of the car.
Yes plastic. The chrome plating rubs off.Or...a 100k car and a $10 fob that would cost $300 to replace.
❓ QUESTION Key fob battery replacement | Lotus Emira Questions | 2 | ||
D | Key not in car | Lotus Emira Problems and Issues | 8 | |
My new key chain. | Lotus Chat | 10 |
