Speedometer, Off?
freeheelbille
I have noticed since day one that the speedometer appears to be off about 2 miles per hour. My radar detector (GPS-enabled), and while using Waze or other map services, always shows 2 mhp faster than the MHP on the dash. This appears more pronounced at highway speed on slower surface streets. Anyone else notice this?
Definitely a few MPH over indicated vs actual.
Interesting...so we are not clocking miles accurately either?
I've noticed that the speedometer measures higher than satellite or radar speed in every car I've every had - apart from the Emira. My Emira seems to measure about the same as my satnav and the same as a nearby radar speed sensor that I pass often; "30MPH Thank You For Driving Carefully"
I need to check my Emira, but as you said, every car I’ve ever had, has read higher than actual.
In my experience the speedometer is pretty accurate, difference only up to 1 mph compared to the GPS speed at cruising.
My Emira reads 1-2 mph higher than GPS speed per Wayz and my radar detector.
I also show google to be exactly 2 mph slower than the car says. Do we have to account for the curvature of the earth or something for the gps? 😏
I guess this is how they do 0-60 readings…. More like 0-58
I also checked and get the same. Reads 2mph high at 60mph.
Fairy typical I would say. Some cars over read slightly more. Not seen any under read or even be spot on.
I think this is 100% normal.
It’s to account for tyre wear iirc.
A tyre with typical 8mm tread will have about 2.5% less circumference when it’s bald than when it’s new.
So it will be spinning faster at any given real (gps) speed and the car’s speedo will read higher.
