Software update ruined track mode?
Does that have any impact on manual shifting via the paddles? I also use mostly the track mode but never let it do auto shifting.
No impact to paddles/manual shifting as far as I can tell. Can’t be sure but feels like throttle response and possibly exhaust note at high RPM were impacted. Essentially, the car is EXACTLY the same in track as it is in sport with the exception of traction control. Same shift points, same responsiveness, same sound
There are no variants. Just convertible and not convertible. All same suspension etc. just aesthetic shit and roll bar option for coupe.
I’d suggest trying 600lt, 675lt or 765lt.
You’ll be disappointed but 720s. It’s a 911 turbo s instead of a gt2 / 3rs
Ditto on 675lt
Has anyone confirmed if this update affects the V6 manual? It sounds like it is an automatic transmission thing but wondering if the idle change, etc. has made any difference in the manual cars?
Did some test drives today at low, mid, and high speeds. Can confirm the under 40mph is garbage. The quick acceleration from a standstill up to 100 seems unaffected. I’d even say the 0-60 may be slightly faster but I was not measuring with anything except my seat. The switch from tour to track doesn’t have that same noticeable sound of the engine waking up and drowning out your radio. That parts hurts the most.
As others stated the paddle shifting is unaffected and that’s pretty much where I live now.
V6 auto here - can confirm track mode was impacted after a recent software update. Agreed that it is essentially the same as sport mode now. Any track mode requires paddles (watch the redline so it doesn’t abruptly cut the throttle!)
I will have my v6 manual ecu done shortly, will let you know
Might be ECU having to learn again after an update. Im v6 auto and track mode definitely feels better and louder than sport but maybe I had an update before? My creep is 5mph which was the same update as the track mode changes correct
I had my manual updated not too long ago and my Track mode still increases revs at idle.
