Seat memory
TJM
New member
The seat memory has stopped working. The seat motors still work and the position can be adjusted with the seat side controls. Lotus garage says they found a code which indicates the whole seat needs replacing. I find that very hard to understand. Has anyone had any experience of this?
What code did the garage read for this?
Also which garage is this?
I find that easy to understand - the factory service manual pretty much has you replace any assembly if something is out of spec, with no further diagnosis or repairs elaborated. :-/
DTC B159F96 Seat Module Right slide motor sensor component - internal failure.
Silverstone.
Sounds like ReadT is right then. You can't just replace the seat motor module & have to have a whole new seat.
As it's Silverstone they won't be messing you around either.
I guess you either get a new seat under warranty - or if no longer under warranty it's an good excuse to buy Tillet seats. So a win-win ;)
If not under warranty there may be someone that has fitted Tillets (or plans to) that has a spare seat.
